Thread: S4 B6 ABS Problem
Results 1 to 10 of 18
  1. S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    I have an ABS problem on my B6 S4 which is driving me nuts.
    Engines starts fine and car runs well. However, ABS light (solid) and brake light (flashing) on dash.
    Also noticed that the brake lights are on permanently.
    Tried VCDS and it will not communicate with the ABS module.
    Looked at many posts on forums and have changed brake light switch, ABS electronic module, even central electric unit. No change.
    One of the errors on VCDS is,
    00625 - Vehicle Speed Signal
    27-00 - Implausible Signal
    So I checked MVB as follows,
    Central Electric 014.2 326.4km/h
    Engine 005.3 0km/h
    Instruments 001.1 326.0km/h
    Not sure where it's getting these speed values from? Could it be that it won't communicate with the ABS module when it thinks the speed is so high?
    Would really appreciate some pointers.
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
    67 69 75 76 77
    VIN: WAUZZZ8E43A329927 Mileage: 139650km-86774miles
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 HW: 8E0 907 560
    Component: 4.2L V8/5V G 0030
    Coding: 0011711
    Shop #: WSC 63351 000 00000
    VCID: 62C0A06ABEB36056E7-5102
    2 Faults Found:
    18057 - Powertrain Data Bus
    P1649 - 008 - Missing Message from ABS Controller
    18080 - Coolant Fan Control 1
    P1672 - 004 - Open or Short to Ground
    Readiness: 0110 1101
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 Q
    Component: A4 Klimaautomat 1116
    Coding: 00000
    Shop #: WSC 63351
    VCID: 2F66195EEDE19D3E38-5102
    4 Faults Found:
    01592 - Air Quality Sensor (G238)
    37-00 - Faulty
    00819 - High Pressure Sensor (G65)
    29-00 - Short to Ground
    01206 - Signal for Duration of Ignition Off Time
    01312 - Powertrain Data Bus
    79-00 - Please Check Fault Codes
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 01011
    Shop #: WSC 63251
    VCID: 356A2B360FBDA7EE72-4ACE
    1 Fault Found:
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 2000
    Coding: 0010702
    VCID: 36682C3A42BBACF67B-50E6
    No fault code found.
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0308
    Coding: 00042
    Shop #: WSC 63251
    VCID: 3E78341A3A8B64B6A3-4ACE
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 980 L
    Component: KOMBI+WEGFAHRS. RB4 D36
    Coding: 01401
    Shop #: WSC 00010
    VCID: 356A2B360FBDA7EE72-5102
    WAUZZZ8E43A329927 AUZ6Z0C0013263
    1 Fault Found:
    01316 - ABS Control Module
    49-00 - No Communications
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
    Component: RNS-E HIGH EU H74 0650
    Revision: 04S Serial number: AUZBZ7G0048014
    Coding: 0309713
    Shop #: WSC 06335 000 00000
    VCID: 3260102AAED3B0D657-5120
    1 Fault Found:
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Time Indication: 0
    Date: 2002.02.23
    Time: 20:29:19
    Freeze Frame:
    Bin. Bits: 0010
    Mileage: 655350 km
    Count: 2302
    Clock: 20:29
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: 6BDECD4E1979211E54-5120
    Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1211
    Coding: 07115
    Shop #: WSC 63351
    VCID: 73EED52E4149F9DE9C-4ACE
    Subsystem 1 - Part No: 8E2959802
    Component: Tőrsteuer.FS BRM 0002
    Subsystem 2 - Part No: 8E2959801
    Component: Tőrsteuer.BF BRM 0002
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0003
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0003
    1 Fault Found:
    01134 - Alarm Horn (H12)
    Address 55: Headlight Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    VCID: 040C86F214E7CE66B5-4ACE
    Address 56: Radio Labels: 8E0-035-192-RNSE.clb
    Coding: 0309713
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 161
    Time Indication: 0
    Date: 2002.02.23
    Time: 20:29:19
    Freeze Frame:
    Bin. Bits: 0010
    Mileage: 655350 km
    Count: 2302
    Clock: 20:29
    Address 76: Park Assist Labels: 8Z0-919-283.lbl
    Part No: 8Z0 919 283 A
    Component: Parkingsyst. A4 RDW D09
    Coding: 00114
    Shop #: WSC 63351
    VCID: 438E45EE5169095ECC-50E6
    1 Fault Found:
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
    Component: FSE_256x BT H34 0600
    Revision: 00000000 Serial number: 00000005128365
    Coding: 0010722
    Shop #: WSC 00000 000 00000
    VCID: 75EAEB361F3DE7EEB2-50E6
  2. Re: S4 B6 ABS Problem
    Jul 2015
    Staffs
    46 Post(s)
    Water in the scuttle area? Blocked drains? Water logged relays under the ECU?
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    Thanks for the suggestions.
    ECU box is bone dry inside. Not entirely sure about scuttle and drains. Can you confirm where specifically to look please?
    Cheers.
  4. Re: S4 B6 ABS Problem
    Jul 2015
    Staffs
    46 Post(s)
    Under the where the battery sits
    Ian
  5. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    OK, checked under the battery and it's dry. No standing water.
    I'm concerned that the parking assist is showing a speed error. Any idea how to unplug parking assist to eliminate that from the problem?
  6. Re: S4 B6 ABS Problem
    Sep 2008
    chester
    17 Post(s)
    When you changed the abs module have you got the correct coding installed?
  7. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    VCDS can't communicate with the ABS module (old one and new one) so I can't code it.
  8. Re: S4 B6 ABS Problem
    Sep 2008
    chester
    17 Post(s)
    Enter the abs module on vcds do you get the small bar spinning in the top lefthand side,does it say anything in the coding i.e all zero's.
  9. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    Can't remember exactly. Will try again tomorrow and report back.
  10. Re: S4 B6 ABS Problem
    Sep 2008
    chester
    17 Post(s)
    Did you fit a new abs module or used /repaired unit.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
