Thread: S4 B6 ABS Problem
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    It was a used module.
  2. Re: S4 B6 ABS Problem
    Sep 2008
    chester
    17 Post(s)
  3. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    Tried the ABS module in VCDS again. No coding shown in any of the fields. Just tries to communicate on a few channels and then fails saying it can't communicate.
  4. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    http://www.bba-reman.com/gb/content....a4_fault_codes
    Sorry, not sure I understand what to do with these error codes. Where do you find them on the car?
  5. Re: S4 B6 ABS Problem
    Sep 2008
    chester
    17 Post(s)
    They are some of the fault codes that may be present in a faulty module but if there's no comms you wont see them,I suspect you've need to send it off for testing,that's the problem with a secondhand unit it too could be corrupted,at least if its tested or repaired you're starting from a known position,some of the symptoms you have gotten are indicating a failed unit. ( wheel speed sensor and no comms)
  6. Re: S4 B6 ABS Problem
    Mar 2016
    Boldon, England
    OK, I understand. Thanks for the advice.
    Are there any recommendations where to send it to?
  7. Re: S4 B6 ABS Problem
    #17
    Sep 2008
    chester
    17 Post(s)
    BBA reman,go through ebay they've got a or best offer on,least ways it'll be tested.
  8. Re: S4 B6 ABS Problem
    #18
    Mar 2007
    Ipswich, UK
    7 Post(s)
    BBA Reman reconditioned an ABS unit for me for a BMW K1200S motorcycle that I had at a cost of £320 instead of a new one from BMW for £1200 and it was fine never had a problem with it and they gave a better warranty on the reconditioned unit than BMW gave on a new one!
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
