Thread: fans running with ignition
  1. fans running with ignition
    Dec 2009
    langley, uk
    HI....having terrible trouble diagnosing this fault. When the ignition is on, the slow fans run, and the Engine management light stays on. The fans go off again when ignition is off. The water temp is fine, and heating works great. My mechanic put the diagnostic do da on it, and it shows up as having a problem with the thermostat....even though it appears to function normally. can anyone help with this one? MOT is due. suspecting that there is a sensor inside the stat, but can't change that.
  2. Re: fans running with ignition
    Southampton, UK.
    I changed my thermostat recently and it was a purely mechanical device, ie. no electrical connections, just like they have been for years. A faulty one wouldn't come up on a diagnostics test. I would start with looking at the coolant temperature sender or the temperature sensor in the rad. What your mechanic is saying sounds complete rubbish to me.
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: fans running with ignition
    Dec 2009
    langley, uk
    Hi Herby, No, there is...I changed the whole coolant housing myself twice over the years, as it is 17 yrs old. I have the 1.6 8v AKL auto model, which is different from yours I'm guessing. A diagnostic points to a faulty stat, but the water temp is fine, at 90 degs, and heating is all ok. please see pic. I'm wondering if they are using a thermistor in there instead of a rad sensor.
    This is the sensor on the stat housing itself
    This is a pic of the whole coolant housing including the green coolant sensor
    Looking down the pipe something runs from the socket to the back of the stat (This is a spare one I have)
  4. Re: fans running with ignition
    Southampton, UK.
    Apologies, never seen one like that before. Does the stat error come back after having cleared all the codes, just to be sure it is a current code?
  5. Re: fans running with ignition
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by fido69r View Post
    Firstly i wouldnt worry about the engine light for the MOT.....isn't it only a advisory?
    Why not change the housing and sensor then?
    Ian
    A4 B6 Avant Nogaro Blue
  6. Re: fans running with ignition
    Dec 2009
    langley, uk
    yes, the fault light does come back every time....I didn't want to go down the changing route until I was sure that this was the problem. I haven't come across anyone on the forums that seem to had this problem before, and it's bugging me.
  1. Question 2006 1.9tdi Caddy - Fans Run with Ignition On
    By Hellbilly in forum The Commercial Range
    Last Post: 08-01-2018, 10:36 PM
  2. Both fans running from cold
    By Simple Si in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2016, 09:14 PM
  3. Fans running when engine off.
    By Rockape63 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-09-2013, 05:42 PM
  4. Question Fans running, engine off, DPF very hot???
    By logiclee in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2010, 04:53 PM
  5. Question Cooling Fans running
    By davidebird in forum Octavia
    Last Post: 20-01-2009, 09:25 AM
