Thread: Sticky, frozen windows: What’s your solution?
Results 1 to 10 of 13
  1. Sticky, frozen windows: What’s your solution?
    May 2009
    Stirling, Scotland
    Seen this on many forums that Audi (and BMW) suffer from frozen windows that don’t drop properly to let you in your car. I’ve so far managed to get round this mostly successfully with silicone grease and on severe mornings, a credit card inserted between the window and door rubber but it’s a real pain. I cannot believe Audi didn’t spot this in sub zero testing facilities. Anyone know of a less messy solution as I’m starting to turn into Slick Willie with all the grease on me!
  2. Re: Sticky, frozen windows: What’s your solution?
    Aug 2007
    Move South ?
  3. Re: Sticky, frozen windows: What’s your solution?
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    On a lot of the detailing pages they mention glass sealant and paint sealant etc, it stop the frost getting a hold on the surface, meaning even if it looks frosty it slides straight off with no resistance. Might be worth looking at something like that.
  4. Re: Sticky, frozen windows: What’s your solution?
    May 2009
    Stirling, Scotland
    Brilliant but atad expensive option lol. Relocate or spend £5 on a tub of grease. 🤔
  5. Re: Sticky, frozen windows: What’s your solution?
    Feb 2013
    Gloucester
    57 Post(s)
    Squirt a jet of de-icer around the window before you try to open it.
    Sent from my iPhone using Tapatalk Pro
  6. Re: Sticky, frozen windows: What’s your solution?
    Oct 2018
    Westbury
    Hi,I have a Audi TT MK3 with a window problem following overnight frost.Windows don't retract so unable top close the doors, resulting in not being unable to drive it.Contacted Audi UK , they advised me to book in with my local dealership (again).They carried out a modification by resealing, back in March 18.Had a first frost this morning & ha ho same problem , fortunately the car was still under warranty & the repairs have a further years warranty, so hopefully they can sort it out this time.
  7. Re: Sticky, frozen windows: What’s your solution?
    1840 Post(s)
    I can’t see how they can prevent water turning into ice when it gets cold. A thin layer can be worked around but if you have a thick lump of ice stuck to the window and its pressed wiping rubber, no amount of engineering will get around it. This is why in cold countries they plug their cars in to the mains to keep them above freezing.
  8. Re: Sticky, frozen windows: What’s your solution?
    Sep 2018
    Witney UK
    19 Post(s)
    Deicing fluid/spray is the cheapest solution.
    2017 Audi Q5 Quattro S line Navarro Blue 2.0 litre TFSI, HBA, Powered Mirrors, QVIA AR790 (2 Channel Dash Cameras), Front & Rear parking cameras with smart interface.
  9. Re: Sticky, frozen windows: What’s your solution?
    Jun 2006
    UK, Mids
    Try thumping the glass a few times before you open - it shears the ice where it bridges the gap. Can't say if it works on an A7 as I dont have one but worked for me on a mazda.
    Audi A8 - 2015 - 3.0TDI
  10. Re: Sticky, frozen windows: What’s your solution?
    Apr 2016
    Bathgate
    Have you tried Krytox for this. Its used for the door seals and in reading stuff about Krytox it can bond with rubber, which is why the door seals are coated with a layer to stop squeaks. It also has very high environmental specs so I've used it on the window edges and have had no issues with freezing.
  1. FL A6 Avant - Frozen MMI?!
    By St3veM in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 15-08-2015, 05:01 PM
  2. Frozen MMI
    By Rower1978 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-05-2015, 12:55 PM
  3. Windows frozen
    By belly buster in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-01-2014, 01:09 AM
  4. Electric Windows - Sticky
    By MathewRB in forum Polo - Derby - Lupo - Fox
    Last Post: 06-11-2010, 04:06 PM
  5. Please Help CD changer has frozen
    By n8ckh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-06-2008, 12:58 AM
