Thread: A6 won't warm up...
Page 4 of 4 FirstFirst ... 234
Results 31 to 32 of 32
  1. Re: A6 won't warm up...
    #31
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Quote Originally Posted by bluezie View Post
    I have a 2014 3.0 Q, and there is no coolant shut off valve. The coolant runs through the heater matrixes at all times, and the heat output is adjusted by motorized flaps blending hot and cold air.
    Sounds like you have a sticking flap in the climatronic. Using VCDS, you can check all the flaps and sensors.
    I stand to correct myself, there is a coolant shut off valve on the C7, I was thinking about my C5 which doesn't, so coolant flows through the heater at all times.
    That said, the above fault with a stuck flap can still cause slow, or no warm up of cabin temperature.
  2. Re: A6 won't warm up...
    #32
    Jul 2017
    Manchester
    Error code is B109007 - Defroster flap motor mechanical malfunction passive/sporadic
  1. 2.0 Tdi Warm up?
    By c7john in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 04-12-2012, 09:33 PM
  2. Question 2.0tfsi warm up
    By farmermo in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-11-2012, 12:30 PM
  3. Better MPG now its warm?
    By podwin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-04-2009, 08:57 PM
  4. Car getting too warm?
    By mpm1987 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-04-2009, 08:08 AM
  5. creaking when warm??!!
    By ChrisB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-07-2007, 03:14 PM
