Thread: Mk6 rubbish when cold
  1. Mk6 rubbish when cold
    Feb 2018
    Doncaster
    Over the past week it’s been around freezing overnight and I have noticed a very strange issue with my car.
    It starts on the turn of the key, ticks over like normal, and you can rev it with the clutch in once warm to the redline without any issues. However the issue is under load, usually when cold. I drive off the estate slowly and once on the main road I accelerate to 60mph, not quickly just standard driving. I then receive a strong shake and judder, like I have changed from 1st to 5th gear and it’s about to cut out. I can drive through this, then a knocking sound appears from the engine. It again is only under load and seems to quieten once the car is fully up to temperature.
    So in summary,
    It judders, knocks and uses extra fuel
    I don’t get any smoke, there are no codes registered and there is plenty of oil.
    One thing I have noticed is, this is sometimes when I am on less than 50 miles on the obc left before filling up.
  2. Re: Mk6 rubbish when cold
    1835 Post(s)
    Engine type? If it is a diesel the in tank fuel pumps often fail and cause starvation.
  3. Re: Mk6 rubbish when cold
    Feb 2018
    Doncaster
    It’s a 2011 61 2.0 tdi 140, has 170k and never had any issues with it before.
    Do you need the specific engine model? If so where do I find it?
  4. Re: Mk6 rubbish when cold
    1835 Post(s)
    So what you are saying is it is a seven year old car with 170K miles on it and because it has never gone wrong before you don't understand why it has?
    Has the emissions recall been done?
    What are you using to read the fault codes?
  5. Re: Mk6 rubbish when cold
    Feb 2018
    Doncaster
    Sorry I need to add context..
    AA used some scanner connected to the obd port while it was idling and moving. Cylinder 1 and 4 were minus numbers, 2 was 1.4 or 1.04 and 3 was 0.8
    AA said to run a tank of super diesel through it and see what happens. He suggested poor fuel, my comment on here about not having any issues was related to it’s always had standard fuel, mainly from supermarkets in it, and I haven’t had any other engine work done, so the car is totally standard.
    To answer your question, it has had the emissions ecu update and has been ok for 12k miles.
  6. Re: Mk6 rubbish when cold
    1835 Post(s)
    The injectors on the CRTDI 2L can go wrong but they are not as unreliable as the 1.6. Before changing them, their signals would need to be carefully studied because at £438 each you would not want to get it wrong.
  7. Re: Mk6 rubbish when cold
    Feb 2018
    Doncaster
    Ok I had it towed again and after a leak off test it’s apparent injector 2 is buttered and 3 is on its way out.
  1. e bay rubbish.
    By zollaf in forum Chat - Anything with wheels
    Last Post: 09-02-2010, 09:25 PM
  2. Rubbish brakes
    By alanstead in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2009, 09:36 PM
  3. What a rubbish Day!
    By NeilGriffith in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2008, 04:53 PM
  4. Rubbish when Cold..
    By 01V5 in forum Bora - 1998 - 2005
    Last Post: 27-02-2008, 07:16 AM
  5. Rubbish headlights
    By karsim1 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-07-2006, 03:15 PM
