Thread: Coolant Sensor Access AVG 1.9 TDI Engine.
Results 1 to 10 of 10
  1. Coolant Sensor Access AVG 1.9 TDI Engine.
    Jan 2015
    manchester
    8 Post(s)
    Apologies if there are threads for this - I couldn’t seem to find one specifically for the AVG engine. My temp gauge will go to 90 then zoom straight down to 0 again. A VCDS scan found ;
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 980
    Component: B5-KOMBIINSTR. VDO D07
    Coding: 00440
    Shop #: WSC 00000
    VCID: 68DFA818086B740639-5122
    Component: AUZ7Z0X1186343
    ���������������� AUZ7Z0X1186343
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    I am presuming the sensor needs changing. I’ve done this on our Audi 80 1Z engine (fiddly and annoying)
    i was was wondering if anyone had any tips to change on my A4. Looks like access is tricky. I bought Haynes manual and the AVG engine isn’t covered! Thanks in advance.
  2. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    1835 Post(s)
    It is on the back of the head in a plastic housing pointing towards the cars right and tight up against the bulkhead, a bit tight to do.
  3. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    Jan 2015
    manchester
    8 Post(s)
    Ok thanks. There are two places I thought it could be today when I took the engine cover off. If I take photos is there a way of posting them, now photobucket charge?!
  4. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    1835 Post(s)
    I have a picture, trapped on photofu*w*t who are a bunch of idiots. I PAID them a subscription and then they said they wanted hundreds of dollars a month, now they are begging me to come back for ONLY $199 a year! Hell will freeze over first. I have opened a Filckr paid account which is less than $10 a month and I am slowy rebuilding my libary.
  5. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Off-topic from the original post (sorry) but I moved all my pictures from Photobucket to imgbb.com and re-linked all images in my posts to their new home. Imgbb is free and they don't seem to care about hotlinking (which was the issue with Photobucket). The hardest part was finding all my posts with images in them
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  6. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    Jan 2015
    manchester
    8 Post(s)
    Great. I’ll check that out and hopefully post some photos so I can identify the coolant sensor!
  7. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    Jan 2015
    manchester
    8 Post(s)
  8. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    Jan 2015
    manchester
    8 Post(s)
    Is that the sensor ? (See above photo!) If so, what is the plastic bottle type thing, and could u remove this to aid access? Thanks!
  9. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    1835 Post(s)
    I have tried to get my pics off of phototwat and failed as now I am no longer on an ad-free subscription my PC gets bombarded with adverts to such an extent I cannot use their web site to retrieve my pictures, they are a sharp practice unprincipled money grabbing con machine.
  10. Re: Coolant Sensor Access AVG 1.9 TDI Engine.
    Jan 2015
    manchester
    8 Post(s)
    Update. Changed the sensor on a Friday - o ring wouldn’t come out so lost all the coolant whilst fishing for it. New sensor fitted, coolant topped up and now running at 90. Fiddly, job but worth it.
  1. Please Help Engine Coolant Temperature Sensor 2.4 V6
    By plugin in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2012, 07:31 PM
  2. ALT engine coolant sensor wiring
    By candradh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-09-2012, 02:38 AM
  3. Engine Coolant Sensor
    By TonyMc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-01-2012, 08:50 PM
  4. Engine coolant sensor on a 2.6 v6?!?!?!
    By nickthegreek_9 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2009, 10:34 PM
  5. Engine Coolant Temp Sensor - where?
    By clarky_two in forum Chat - Anything with wheels
    Last Post: 11-12-2008, 11:13 AM
