Thread: polo 2002 1.2 petrol drive shafts
  1. polo 2002 1.2 petrol drive shafts
    Dec 2017
    EUXTON CHORLEY
    i have an 02 1.2 petrol polo hatchback engine code AZQ i need to change the passenger side drive shaft and would like any hints or tips to go about this, i have bought a new complete driveshaft and also wanted to know what tool do i need to get the torx/splined bolts off at the transmission end of the drive shaft
    Any help or tips would be appreciated
    cheers
  2. Re: polo 2002 1.2 petrol drive shafts
    16 Post(s)
    388 Post(s)
    You will need an M8 XZN hex key for the inner CV flange and a 12 point 36-mm socket with a flat face and no chamfer up into the socket as the nut is very low profile. You MUST use a new nut and make sure this is not one with a flat face, it must be convex but flat face ones are sometimes supplied and these are too short, they rip the end of the joint off. I can't remember the nut torque but I think it is 50Nm plus 90 degrees. If you remind me tomorrow I will check.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: polo 2002 1.2 petrol drive shafts
    Dec 2017
    EUXTON CHORLEY
    Thank you Crasher for your help ,i will let you know how i get on once the weather allows to do the job on my drive
  4. Re: polo 2002 1.2 petrol drive shafts
    Dec 2017
    EUXTON CHORLEY
    i eventually got round to doing this job last Friday spent 2 hrs getting the old driveshaft off and another 2 hrs putting the new one back on so really pleased with myself for a first time effort,the outer cv joint was completely wrecked with the rubber gaiter missing/shredded no wonder i came to a halt all of a sudden and had to be recovered home
    Thanks to Crasher i had the right tools and had a Haynes manual already which was a big help, i also read somewhere on this forum to use wd 40 the night before on all the bolts that needed to be undone and they came off really easy.
    getting the driveshaft hub nut i used the car wheel nut brace over my socket ratchet handle and tapped it once with a lump hammer and it came loose/ to get the inner driveshaft bolts off i had to wedge a piece of 3 x 2 timber between the brake pedal and front seat to stop the driveshaft spinning when loosening the 6 bolts to the transmission end and also put a pair of mole grips on the lower driveshaft so it wedged on the lower suspension arm as i was working solo and had no one to operate the foot brake
    good afternoons work and cost me only 40.00 for the new driveshaft off ebay
    Cheers Tony
  5. Re: polo 2002 1.2 petrol drive shafts
    16 Post(s)
    388 Post(s)
    If you use a wheel bolt with a big nut underneath (the bolt is too long without) to prevent the disc shearing the retaining screw, a decent screwdriver in one of the disc vent holes butted up against the caliper stops the disc rotating.
  6. Re: polo 2002 1.2 petrol drive shafts
    Dec 2017
    EUXTON CHORLEY
    Thanks Crasher
    what size hex/Allen key do i need for the front brake calipers went to change the front pads and did not have the key to fit ,no size stated in Haynes manual and local car parts shop says either 7mm or 8mm
    Cheers Tony
  7. Re: polo 2002 1.2 petrol drive shafts
    16 Post(s)
    388 Post(s)
    Base model 239mm brakes use a cheap (1) M8 bolt through a sleeve and this has a 6mm hex key fitting, bigger engined models with 256mm discs use an expensive (20) purpose made sleeve with an M7 thread and use a 7mm hex key.
  1. Wanted Drive Shafts, where from?
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-04-2015, 05:05 PM
  2. Question B5 drive shafts, are they the same on petrol and TDI versions, saloon and avant?
    By thierry1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-04-2014, 10:51 AM
  3. Question 2005 (MK7) polo clunk over speed bumps, drive shafts have play.
    By PoloJon in forum Polo - Derby - Lupo - Fox
    Last Post: 19-01-2014, 05:49 PM
  4. Question drive shafts
    By stevie-g-2.6 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-05-2010, 05:00 PM
  5. drive shafts
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-06-2009, 10:00 PM
