Thread: Please reduce engine oil - NIGHTMARE
Results 11 to 20 of 30
  1. Re: Please reduce engine oil - NIGHTMARE
    #11
    May 2012
    Everywhere
    308 Post(s)
    The dpf has many enemies , all too often the shorter journeys get the blame .
  2. Re: Please reduce engine oil - NIGHTMARE
    #12
    Tripletrouble Guest
    My car regens for a hobby. I can come off a 200 mile motorway run at 75mph and as I get on the drive it starts to regen FFS. This will be my last diesel car.
    It also uses almost as much AdBlue as diesel!! In 8k miles I've just topped up with 10l again meaning I've put in 30l so far!!
  3. Re: Please reduce engine oil - NIGHTMARE
    #13
    Mar 2014
    United Kingdom
    33 Post(s)
    We had a diesel Fiat 500 ten years ago - our first diesel with a DPF, and before I became aware of the risks inherent with DPFs on short journeys. We bought it to commute 1.5 miles to work and then home again each day.
    We needed a new engine at 6,500 miles. Even then, we weren't told why (it was diesel contamination of the oil) and I don't think the dealership even knew what was going on.
    The second engine started to fail at 9,000 miles and by then we knew what the problem was so the dealership bought it back off us at a very generous PX against another Fiat 500 with a petrol engine. Shame, it was a lovely diesel and super economical. A friend of my brother saw off two engines in his jaguar doing exactly the same thing - both well within the warranty. Jaguar bought his car back off him, too.
  4. Re: Please reduce engine oil - NIGHTMARE
    #14
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Does anyone know how to tell when the DPF is regenerating. If we knew, we could drive for a bit longer. I was thinking of attaching a light to the power supply that triggers the regen but don't know which wire from the diagnostics port.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  5. Re: Please reduce engine oil - NIGHTMARE
    #15
    May 2012
    Everywhere
    308 Post(s)
    You've hit the nail on the head there considering the diagnostic capability there's no info for the car to tell you dpf regeneration is taking place .
  6. Re: Please reduce engine oil - NIGHTMARE
    #16
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Gazworld but there must be a way of linking a wire to the dpf. Crasher, any idea?
  7. Re: Please reduce engine oil - NIGHTMARE
    #17
    Apr 2009
    Surrey
    174 Post(s)
    The only visual sign you get while the car is running is that the idle speed rises slightly when it is doing a regen. On my car it goes from roughly 800rpm to just under 1000
  8. Re: Please reduce engine oil - NIGHTMARE
    #18
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks john. what engine do you have. after 7 years of driving, I have not noticed my revs go up. I am determined to find a better way. may be a trigger from the cooling fan or EGR which I think switches off when the regen occurs. Need to read lots.
  9. Re: Please reduce engine oil - NIGHTMARE
    #19
    Nov 2009
    Stratford upon Avon UK
    36 Post(s)
    OK so on my BiTdi I can tell if it's doing a regen whilst I'm driving.
    - Car starts to hold lower gears e.g. BiTdi should drop into 8th at 60mph on modest throttle, it'll stick in 7th Also apparent in lower gears if you learn what gear it SHOULD be in at what speed (e.g. 30 mph should be 5th but it will stay in 4th)
    - I also notice that the exhaust is more noisy... this may just be the lower gears being used.
    - And if you have the lap timer enabled via VCDS you can see oil temp, that's a real giveaway as it will be significantly higher. Normal driving at this time of year my oil temp is in the mid 80C range, when a regen is occurring it will be up into low 90s normally 92 / 93C
    Not sure if they are injecting diesel into the exhaust manifold to burn off the DPF contents (it's one common approach) but my guess is that they are and the exhaust manifold is getting hot and generally heating up the engine so oil temp climbs.
    I've had the car nearly 5 years so I know how it should behave.... now I can tell every time when it's doing a regen and if I arrive home whilst it's doing it I'l take it straight back out, in sports mode (higher revs, more turbo boost / fuel / heat to help regen) and drive until I see oil temp drop below 90. Then stick it in normal gearbox and see if 60mph gives me 8th. If so go home.
    You also notice that fuel consumption is markedly increased during a regen. e.g. remaining range of 150 miles and you see it drop to 140 in 5 miles.
    A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
  10. Re: Please reduce engine oil - NIGHTMARE
    #20
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by shabazmo View Post
    I have the 2.0TDi Ultra but it was the same on the 2.0TDi 177 I had before.
  1. Please reduce engine oil
    By Redcar01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2016, 06:39 PM
  2. Reduce oil warning
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-03-2014, 11:34 AM
  3. Please Help t4 1.9d engine nightmare
    By type2head in forum The Commercial Range
    Last Post: 18-03-2009, 10:23 PM
  4. egr blanking plates vs vag com reduce on afn engine
    By hongkongstuey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2008, 07:40 PM
  5. 2001 Passat TDi 130 Engine running fault nightmare
    By Passatnightmare in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:48 PM
