Thread: Please reduce engine oil - NIGHTMARE
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: Please reduce engine oil - NIGHTMARE
    #21
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    I agree John, mine starts ticking over at 1000rpm rather than about 800rpm. A light or message on the dash would be a much better idea but then again so would a dipstick
  2. Re: Please reduce engine oil - NIGHTMARE
    #22
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    Just heard back from Wearside Audi, turns out the oil level sensor was faulty and oil had ran into the electrical connection/plug giving irrational readings. Covered under warranty thank god!!
  3. Re: Please reduce engine oil - NIGHTMARE
    #23
    Mar 2014
    Edinburgh
    235 Post(s)
    Glad it’s all sorted. This is more the reason they should put a normal dipstick in these cars. Can’t trust these electronic gauges. Don’t even trust the fuel gauge sometimes 😄
  4. Re: Please reduce engine oil - NIGHTMARE
    #24
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    Quote Originally Posted by A6S View Post
    Don’t know why they don’t have a normal dipstick as a backup and my fuel gauge is also temperamental anyway the nice man from Audi also said my front brake pads were 80% worn and quoted £179 to replace the front pads just got a price from euro parts for £40 and should only take a couple of hours to fit....
  5. Re: Please reduce engine oil - NIGHTMARE
    #25
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Quote Originally Posted by Pete_NorthEast View Post
    If it takes you a couple of hours you must be having too many coffee breaks, I did mine last year on driveway in about 45 mins, that's including a coffee between wheels.
    BTW when you get pads double check you get wear sensor, or if your lucky your current sensor hasn't worn through yet. The sensor is just a loop of wire, simple but it works.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  6. Re: Please reduce engine oil - NIGHTMARE
    #26
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    Quote Originally Posted by KevTrem View Post
    Ha ha, I do enjoy a coffee
  7. Re: Please reduce engine oil - NIGHTMARE
    #27
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Just read the handbook and it says that when the dpf is regenerating there will be a warning light on the dash. In 7 years of driving my 3.0tdi, I have never seen the lamp light up. Can anyone confirm that they have see the lamp light up.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  8. Re: Please reduce engine oil - NIGHTMARE
    #28
    Tripletrouble Guest
    Never
  9. Re: Please reduce engine oil - NIGHTMARE
    #29
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    No I was told at Audi that the light only illuminates after x amounts of failed regen attempts...?
  10. Re: Please reduce engine oil - NIGHTMARE
    #30
    Jul 2016
    Chestfield kent
    81 Post(s)
    Hi read in a thread, but can't find it at the moment, that the light only comes on if the DPF is 50% or more blocked. Would kind of make sense as mine has never come on in over 2 years, and I know it's done regens ! Any Audi tech that can enlighten us ?
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  1. Please reduce engine oil
    By Redcar01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2016, 06:39 PM
  2. Reduce oil warning
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-03-2014, 11:34 AM
  3. Please Help t4 1.9d engine nightmare
    By type2head in forum The Commercial Range
    Last Post: 18-03-2009, 10:23 PM
  4. egr blanking plates vs vag com reduce on afn engine
    By hongkongstuey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2008, 07:40 PM
  5. 2001 Passat TDi 130 Engine running fault nightmare
    By Passatnightmare in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:48 PM
