Thread: Puff of smoke on start up
  1. Puff of smoke on start up
    Aug 2007
    Nottingham
    Hi guys.
    I have noticed more recently (maybe to do with colder weather) that on cold start I get puff of smoke (white/grey) from the exhaust. The car is a 2009 2.0 TDI Passat B6 Sport - The engine runs sweet and no issues with mpg/oil/fuel or idle.
    When the car is warm it does appear to do, only on cold start. No light on dash. I wasn't able to smell it as the smoke only lasts a few seconds.
    What could this be? I have access to VCDS but not sure what checks I should make.
  2. Re: Puff of smoke on start up
    Jul 2015
    Staffs
    46 Post(s)
    I wouldn't worry too much, but change the glow plugs as this is more than likely the culprit.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Puff of smoke on start up
    1840 Post(s)
    A code read of the engine ECU will tell you if there are any failed glow plugs.
  1. High revs on start up and a puff of black smoke
    By portovechios in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-08-2012, 10:39 AM
  2. Please Help Any TDI Guru's? AHU/1Z Delay in power then puff of smoke??
    By shwni in forum Early Passat Forum - Pre 97
    Last Post: 15-03-2011, 09:07 PM
  3. Puff of white smoke on starting
    By mickyboy22 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-07-2009, 09:28 PM
  4. Big Puff Of Smoke
    By lamondi in forum 80 - 90
    Last Post: 15-02-2009, 05:05 PM
  5. Question Puff and the white smoke
    By nathancrowster in forum Golf MK4 - 1999 - 2004
    Last Post: 31-12-2008, 06:29 AM
