Thread: Wierd Happenings 2010 Golf
  1. Wierd Happenings 2010 Golf
    Sep 2009
    scotland
    I have a 2010 Golf 1.5 diesel, been in the family for 7 years now. There is something weird going on with the car. When the ignition is switched on and the car is started even when the car is not started a number of things seem to happen:
    1. Temp sensor needle intermittently drops to zero then jumps up to approx 45 degrees;
    2. In conjunction with the temp sensor needle the rev counter needle does the same drops to zero then back up to idling at 10;
    3. Battery light and power steering light take it in turn to alternate between one going on and the other going off, then on then off,
    4. The doors lock and unlock repeatedly.
    I am hoping one of you guys has seen this behaviour before? If so any advice would be greatly appreciated.
    cheers
    Sd
  2. Re: Wierd Happenings 2010 Golf
    Aug 2016
    South Lakes, UK
    29 Post(s)
    Could it be the battery is on its way out? Not had those problems myself just making a suggestion as I know cars can misbehave when the battery is going. At 7 years old and in the colder months is a possibility
    Sent from my ONEPLUS A3003 using Tapatalk
  3. Re: Wierd Happenings 2010 Golf
    1840 Post(s)
    Yes that could well be a weak battery, the astonishing thing is, due to the permanent magnet starters, they will crank the engine over and even let it run but ancillaries will go nuts if the engine is not running. An S8 we had in over Christmas was so flat this morning that we could not get the key back out of the ignition after trying to start it, the alarm was going nuts as was the dash and the boot would not open (which is where the battery is!!!!) but the bloody thing was trying to turn over, all ten cylinders of it!
  4. Re: Wierd Happenings 2010 Golf
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I had similar haywire dash warnings one christmas day a few years back, car would start fine and faults would clear after about 10 mins running, but reappear at the next cold start. Battery was struggling to hold charge overnight, new one sorted it out.
  5. Re: Wierd Happenings 2010 Golf
    Sep 2009
    scotland
    Thanks for the reples guys, will get the battery checked out.
  6. Re: Wierd Happenings 2010 Golf
    Feb 2018
  1. Odd brake happenings! !
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-02-2018, 01:16 PM
  2. Random Electrical Happenings - Help appreciated
    By Nicola913 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-08-2016, 04:03 PM
  3. Strange happenings?
    By Almur in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-12-2013, 04:06 PM
  4. Srange happenings 2010(March) Golf GTD 7000 miles
    By NORTONXSU in forum Golf MK6 - 2009 - 2013
    Last Post: 29-06-2011, 12:58 AM
  5. Warning light weird happenings
    By diddly in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-04-2008, 04:30 PM
