Thread: Central Locking Slow
Results 1 to 9 of 9
  1. Central Locking Slow
    Jan 2015
    manchester
    Hi all.
    Central locking from both the remote key and manual key (turning in drivers door) seems slow. A VCDS scan brought up a fault code (possible leak)
    When I turn the key manually in the drivers door lock it's extremely stiff but it does turn and unlocks and locks.
    My questions are ; will this eventually lead to complete failure and with it not being able to get into boot and the other three doors? How much for a fix/new pump?
    Thanks!
  2. Re: Central Locking Slow
    Mar 2016
    Minervois, France
    22 Post(s)
    I think your locks are similar to mine, which don't have remote locking, but have the same locks and actuators.
    Do both the remote and manual keys lock and unlock all the locks properly? Is it just the driver's door which is stiff? Is the lock also stiff if you unlock from the passenger door?
    The manual key turns a driver plate at the end of the lock cylinder. The plate has a lever which moves a rod connected to the actual lock, and gear teeth which turn a small pinion to simultaneously operate a microswitch.
    The microswitch contact runs the vacuum pump in the Comfort Control Unit, which provides suction, via flexible plastic pipes, to operate the other lock mechanisms at the same time as the key is unlocking the lock which it is in.
    In your case, it seems to me that there could be a fault or a leak in the vacuum pump or piping, or that the locking mechnisms in the door catches are stiff.
    EDIT: The fact that the driver's door key is stiff suggests that the locks themselves are stiff, so is also difficult for the suction system to move them.
    1996 A4 Avant 1.8T engine code AEB automatic with 55,000 kms - 35,000 miles.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  3. Re: Central Locking Slow
    Jan 2015
    manchester
    Thanks for that! It only has a lock on the drivers door so my worry is that if the lock fails I can't get in the car as there is no other way in!
    The remote key opens and locks the car but the boot latch button on the remote key doesn't seem to work. When I've got some time at the weekend I'll try lubricating the drivers door lock and see if it helps.
  4. Re: Central Locking Slow
    Mar 2016
    Minervois, France
    22 Post(s)
    I think you must mean it has a key operated lock only on the driver's door, as all the doors have locks
    So your passenger, rear doors, and boot/tailgate lock only via the remote, or by pushing down the interior buttons?
    Whether or not there is a key mechanism, manual lock operation is probably similar to mine.
    The suction lock operation is inherently slow compared with the more common electrically operated system. My driver door unlocks immediately using the manual key, although it is slightly stiff to turn, but the other locks take a second or so longer. I can hear the pump (inside the Comfort Control Unit in the back of the car) running while the lock buttons go slowly down.
    My doors all lock simultaneously by turning the key in the lock on the driver door, passenger door, or tailgate, or by presssing down the interior lock button on either the driver or passenger door. The button on each rear door locks only that door.
    The fuel filler flap locks together with the doors.
    Lifting the interior door handle once on either the driver or passenger door unlocks all the doors, a further lift is required to open the door.
    A single lift on either rear door unlocks only that door, also needing another lift to open it. That rear door will stay unlocked if it is then closed (so you can't lock yourself out by locking from the front, climbing over to the rear and getting out from there)
    Turning the key in the tailgate lock a small amount to the right locks everything normally. Turning it all the way to the right also locks everything, but all the other doors, tailgate, and fuel flap, remain locked when either the driver or passenger door is unlocked. All the doors can be unlocked in the normal way from the tailgate lock, or each one individually.
    The driver and passenger windows close when either of these doors is locked, if the key is turned further than the usual amount to just lock the doors.
    So, judging by the slight delay on my car, if your doors all lock within a second or so, that system is probably OK, and the only problem is a stiff locking mechanism or key barrel on the driver's door.
    Unfortunately the locking mechanisms are inside the door trim panels, which are a bit of a sod to get on and off (on my car, at least)
  5. Re: Central Locking Slow
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by jacksticks View Post
    Hi all.
    Thanks!
    To cure the stiff lock have you tried spraying lube into the key hole?
    Ian
    A4 B6 Avant Nogaro Blue
  6. Re: Central Locking Slow
    Jan 2015
    manchester
    Quote Originally Posted by rowdy-999 View Post
    yeah, seems a little easier now.
  7. Re: Central Locking Slow
    Jan 2015
    manchester
    Thanks for all that! Yes, only a key on the drivers door - all the doors have locks! The remote key seems to operate all the doors and unlocks the boot lock, but when I try the boot lock button on its own it doesn’t open. Possibly the way the key has been programmed. Thanks again for all the help.
  8. Re: Central Locking Slow
    13 Post(s)
    296 Post(s)
    That likely leak code has come up on just about every 8D series A4 I have ever code read.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  9. Re: Central Locking Slow
    Jan 2015
    manchester
    That's good to know!
  1. Golf MK5 1.9 Passenger door not locking with central locking
    By hussnainh8 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-12-2016, 02:25 PM
  2. Question Central Locking Not locking all Doors On Jetta 2006
    By jamiecorbett in forum Jetta MK3 - 2005 - 2013
    Last Post: 04-04-2011, 10:06 PM
  3. Central Locking Not Locking Drivers Door
    By davieb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-11-2008, 10:37 PM
  4. keys, central locking to remote central locking!!!!!!!
    By Shakey mk4 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2008, 01:35 AM
  5. Coverting Central Lockin to Remote Central Locking
    By hoedawg in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2007, 05:08 PM
