Thread: Rear doors problem
  1. Rear doors problem
    Feb 2018
    Birmingham
    Hi, the rear doors on my A7 wonít open from the outside but do from the inside. I have checked the settings in the MMI and it is set to all doors open. Any suggestions on what it could be, donít really fancy aging £££ to the dealers if itís something that can be easily fixed. Thanks for reading.
  2. Re: Rear doors problem
    Feb 2016
    Hungary
    42 Post(s)
    Quote Originally Posted by B9gsy View Post
    Hi, the rear doors on my A7 won’t open from the outside but do from the inside.
    I'm not sure about your problem.
    Does it mean, that you are not able to open the rear doors with the handles, or does it mean, that if you press the keyfob's open button then the rear doors remain closed?
    If the answer is the keyfob, then please check the passanger door. If that one remains also closed, than you have selected the option in the MMI to not to open all doors with a single press. In this case you have to press the open button twice (if I know well), because the first press will open the driver's door only, and the second press opens all the doors. If you disable this feature in the MMI, then all your doors will be opened by one single press.
    Audi A6/C7 MY2012 Saloon, 3.0 TDI/180 KW Quattro S tronic, Bose, 1BK, PCN, 9R1, PNQ
  3. Re: Rear doors problem
    Feb 2018
    Birmingham
    Quote Originally Posted by AT. View Post
    Hi, sorry I meant the door handles donít open the door. The passenger door opens up ok itís just the rear doors that donít.
  4. Re: Rear doors problem
    May 2009
    Newcastle-under-Lyme Staffordshire
    39 Post(s)
    If it was the opposite way around (ie the doors open using the outside handles but not the inside ones) I'd suspect the child locks are engaged (from the driver's door switch panel).
    Might be a trip to the dealers to sort out your issue here, though.
    Good luck!
    MF.
    2016 A6 Saloon BE Ultra S tronic - Floret Silver, Tech Pack Advanced, Parking Pack Advanced, Heated F+R Seats & Wheel, Electric Seats, Matrix LED, Ambient Lighting, Speed Limit Display, Twin Spoke 20", Folding Memory Mirrors.
  5. Re: Rear doors problem
    Feb 2013
    Gloucester
    52 Post(s)
    Have you had a Vcds scan?
    Sent from my iPhone using Tapatalk Pro
  6. Re: Rear doors problem
    Dec 2015
    Southend, UK
    If both rear door handles packed up at the same time I would suspect it would be electrical. however if one packed up some while ago and the other only just stopped working recently I would suggest removing the rear door cards to check the linkages between the handles and latches.
  1. Rear Doors
    By geoffking39 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-06-2011, 08:42 PM
  2. Rust on Q7 rear doors
    By damilne6 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 23-10-2010, 06:29 PM
  3. Question Rear doors and rubber...
    By DerekHago in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-11-2009, 05:14 PM
  4. Rear Doors
    By Borab0y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-06-2009, 09:59 PM
  5. T5 Rear Doors
    By mon21x in forum The Commercial Range
    Last Post: 07-10-2008, 11:52 AM
