Thread: Some help needed with park brake problem, VCDS log file
Results 1 to 10 of 13
  1. Some help needed with park brake problem, VCDS log file
    May 2008
    40 Post(s)
    Thought I would start a fresh thread to maybe help others in the future when searching.
    Short version, park brake locked on warning on dash, bought obd wind off tool off of ebay which worked once and never again!
    Anyway brakes off so stripped down new pads lubed sliders etc, noticed been standing not to keen to start so new battery and away we go for all of two days then warning came back on whilst driving and epb inop, so did what I should have done in the first place and bought VCDS.
    Anyway its taken me two days to work out how to get the log file so you can see it and hopefully advise me what may be the fault.
    Wednesday,07,February,2018,16:48:48:05925
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
    VCDS Version: 18.1.0.2 (x64)
    Data version: 20180122 DS285.1
    Ross-Tech: Home
    VIN: WAUZZZ4F8BN052995 License Plate: L15AKM
    Mileage: 122460km-76093mi Repair Order:
    Chassis Type: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 55 56 5F 62
    72 76
    VIN: WAUZZZ4F8BN052995 Mileage: 122460km-76093miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine (CDY) Labels: Redir Fail!
    Part No SW: 4F9 910 402 A HW: 4F0 907 401 E
    Component: 3.0TDI EDC17G000AG 0080
    Revision: 16H14--- Serial number:
    Coding: 0105002C190F0128
    Shop #: WSC 00483 210 97008
    VCID: 2411127C52DA8D772CD-8070
    1 Fault Found:
    053271 - Please Check Fault Codes in Control Module for ABS Brakes
    U1017 - 007 - - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 122446 km
    Time Indication: 0
    Date: 2010.04.16
    Time: 03:08:27
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Bin. Bits: 00101111
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 Q HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0070
    Revision: --H05--- Serial number: 4601756
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 3333E120E7341ACFA57-8066
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AL HW: 4F0 614 517 BG
    Component: ESP8 quattro H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    VCID: 6E853054CC9677278A9-803A
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 122446 km
    Time Indication: 0
    Date: 2010.04.16
    Time: 03:08:27
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x02A2
    Hex Value: 0x0024
    Hex Value: 0x0195
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
    Component: FBSAUDIC6 ELV H05 0130
    Revision: 00H05000 Serial number: 10602901727387
    Coding: 0000019
    Shop #: WSC 02324 785 00200
    VCID: 25170F7859E0747F3B3-8070
    Subsystem 1 - Part No: 4F0 910 132 E
    Component: FBSAUDIC6 EZS H03 0020
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0054
    Address 08: Auto HVAC Labels: 4F0-910-043.clb
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0080
    Revision: 00000077 Serial number: 00000030598123
    Coding: 0001046
    VCID: 1D67279871B0BCBF633-8048
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 N HW: 4F0 907 279
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    Shop #: WSC 02335 785 00200
    VCID: 3431E23CE23A1DF7BCD-8060
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H11 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
    Part No SW: 4F0 035 110 A HW: 4F0 035 110
    Component: CDC-MP3-Alp H44 0140
    Revision: AA001001
    VCID: 15773FB88580E4FFAB3-8040
    Address 15: Airbags (J234) Labels:| 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 Q HW: 4F0 959 655 G
    Component: Airbag AU1042 H07 0200
    Revision: -------- Serial number: 003F9004EBMZ
    Coding: 30314236303630303033554A305234463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 3537DF38E5C004FF8B3-8060
    Crash sensor for side airbag: driver side:
    Serial number: 3574SRB40000D0C0F189
    Crash sensor for side airbag: front passenger side:
    Serial number: 3584SRB40000D088DA4H
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3516HRB401M076KAPCJO
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3526HRB402S076KARSI6
    Crash sensor for front airbag: driver side:
    Serial number: 3554NRB400005EBAB42A
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564NRB400005F8E690B
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90025103380325
    Coding: 0102141
    VCID: 270B057023EC666F09F-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments (J285) Labels:. 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 985 E HW: 4F0 920 985 E
    Component: KOMBIINSTR. H10 0209
    Revision: 00000000 Serial number: FV6208V2D
    Coding: 2F560A0502002600010400
    Shop #: WSC 23046 000 1048576
    VCID: 3039EE2C1A2221D7D85-8064
    Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L10B238037
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 392FD308C958E09F6FB-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    Serial number: 00000000002790454344
    2 Faults Found:
    03041 - Energy Management Active
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 100
    Reset counter: 127
    Mileage: 118907 km
    Time Indication: 0
    Date: 2017.10.22
    Time: 02:10:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.10 V
    Count: 18
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 113
    Mileage: 121787 km
    Time Indication: 0
    Date: 2018.01.03
    Time: 08:21:00
    Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
    Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
    Component: TSG FA H12 0361
    Revision: Serial number: 0008000151003
    Coding: 011F06204041410001
    VCID: 48C9A6CC82B28917E05-801C
    Address 46: Central Conv. Labels:. 4F0-910-289.lbl
    Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
    Component: Komfortgeraet H29 0250
    Revision: 02500029 Serial number: 01401489740000
    Coding: 0139771
    VCID: 3537DF38E94004FF8B3-8060
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H05 1501
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H14 0100
    Revision: Serial number: 00000000757731
    Coding: 0001103
    VCID: 5EE560943C36E7A73A9-800A
    Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
    Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
    Component: TSG BF H12 0361
    Revision: Serial number: 0008000149574
    VCID: 47CBA5F08FAC866FE9F-8012
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000321
    Shop #: WSC 02145 785 00200
    VCID: 211F1B684DC8985F47B-8074
    2 Faults Found:
    01487 - System Function Test
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 122456 km
    Time Indication: 0
    Date: 2010.04.17
    Time: 18:20:32
    Freeze Frame:
    Voltage: 13.25 V
    Count: 32
    02442 - Function Lamp in Control Head
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 122456 km
    Time Indication: 0
    Date: 2010.04.17
    Time: 18:20:32
    Freeze Frame:
    Voltage: 13.35 V
    Count: 65
    Address 55: Headlight Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3FDBBD10DB7CCEAF51F-806A
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 056 HW: 4G0 035 056
    Component: Radio U STD H52 0051
    Revision: AB001007 Serial number: 469L90A7637616
    Coding: 010003020100000000
    VCID: 5EE560943036E7A73A9-800A
    1 Fault Found:
    03455 - Function Restriction due to Faults in Other Modules
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 122446 km
    Time Indication: 0
    Date: 2010.04.16
    Time: 03:08:44
    Freeze Frame:
    Bin. Bits: 00000000 00000001
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 652 E HW: 4E0 035 652
    Component: B-BN-EU H60 0147
    Revision: -------- Serial number: 349L60A7554753
    Coding: 010101000002C3ED01000305EF6300030001
    VCID: 231311605BD48A4F557-8076
    Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
    Component: DU6 Basic H42 0084
    Serial number: 9465LP0A0240133
    Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    Serial number: 00000001742495
    Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
    Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
    Component: TSG HL H11 0361
    Revision: Serial number: 0004000176095
    Coding: 010E04204041220001
    VCID: 46D5A8F488A69F67129-8012
    Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
    Component: TSG HR H11 0361
    Revision: Serial number: 0004000176092
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 B HW: 4L0 919 283 B
    Component: Parkhilfe 4-Kan H03 0500
    Revision: 00H03000 Serial number: 37231034600689
    Coding: 0001006
    VCID: 290F034835F8501F1FB-807C
    End----------(Elapsed Time: 01:42, VBatt start/end: 11.9V/12.0V)-----------
    Control Module Part Number: 4F0 910 801 D HW: 4F0 907 801 B
    Component and/or Version: EPB CEFC0090 H05 0090
    Software Coding: 0000321
    Work Shop Code: WSC 02145 785 00200
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 122456 km
    Time Indication: 0
    Date: 2010.04.17
    Time: 18:20:32
    Freeze Frame:
    Voltage: 13.25 V
    Count: 32
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 122456 km
    Time Indication: 0
    Date: 2010.04.17
    Time: 18:20:32
    Freeze Frame:
    Voltage: 13.35 V
    Count: 65
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 122456 km
    Time Indication: 0
    Date: 2010.04.17
    Time: 18:20:32
    Freeze Frame:
    Voltage: 13.25 V
    Count: 32
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 127
    Mileage: 122456 km
    Time Indication: 0
    Date: 2010.04.17
    Time: 18:20:32
    Freeze Frame:
    Voltage: 13.35 V
    Count: 65
    Address 53: DTCs cleared
    Address 01: DTCs cleared
    Address 53,4F0 910 801 D,recoded (Short coding),from,0000321,to,0000321,(02145/785/00200),
  2. Re: Some help needed with park brake problem, VCDS log file
    May 2008
    40 Post(s)
    I should add I deleted all the dtcs and its been fine since, but I know it wont last!
  3. Some help needed with park brake problem, VCDS log file
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Did you code the battery?
    Did you use vcds to push the back brake pads into service position?
    Did you use another battery connected to your car while using vcds to push the brake pads? From my point of view, you should do an output test on brakes, check the dash indicator for brakes it might be deffective, check coding of battery.
    Did you have problems with the steering column or changed/fixed abs/esp module?
    If you coded well the new battery, check alternator for charging, check + and -wires, check wires to alternator, check/replace/used or new BEM and wires to it.
    The dates of the errors are before changing the battery or after changing it?
  4. Re: Some help needed with park brake problem, VCDS log file
    Jul 2013
    76 Post(s)
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 122446 km
    Time Indication: 0
    Date: 2010.04.16
    Time: 03:08:27
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Bin. Bits: 00101111
    Bin. Bits: 00000000
    Bin. Bits: 00000000
    Coding: 0020876
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 122446 km
    Time Indication: 0
    Date: 2010.04.16
    Time: 03:08:27
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x02A2
    Hex Value: 0x0024
    Hex Value: 0x0195
    Hex Value: 0x00FF
    For the above I would be looking at a Clearing of the codes and a rescan then if it returns you need to run the 'Sensor for Steering Angle calibration (G85) in the basic Settings and if this does not sort this out then you could be looking at a new clockspring.
    The parking brake issues may be resolved with the functional test of the parking brake, if the lamp fault persist then do bulb check of the instrument cluster and the parking brake switch this can be done using VCDS in the various module under output tests.
    Electro-Mechanical Parking Brakes (EPB): How to do rear brakes - YouTube
    The other codes are Kind of battery related so a good charge of the battery and a clearing and re scan is first thing to do.
    Dan
    2009/2010 2.0 TDIe SE
  5. Re: Some help needed with park brake problem, VCDS log file
    May 2008
    40 Post(s)
    L3g and Dan
    I will try and answer questions in correct order but dont bank on it!
    Scan was after battery changed
    Battery not coded, I replaced like for like and still not totally convinced the battery is faulty as I have since charged it up on a trickle charger and its holding 12.72 volts in my garage over 48 hrs later.
    Have to say car does spin up quicker and start better.
    I have just printed off the ross tech instructions to code the battery and will have a go later today
    I used another tool I bought off ebay to wind the callipers back to service position then when calliper off the carrier I used a wind back tool to push them fully home (not sure if that was right thing to do?)
    Ebay tool would then no longer work anymore! so sent it back and bought VCDS which I know I should have done in the first place.
    No problems with ebs or steering since we have had the car, dates on them shows years ago but mileage shows current mileage?
    I have cleared all codes today and its been fine since, also checked warning lamp function on the dash and it came on and off as expected with VCDS.
    I also checked the earth jump start point under the bonnet after reading about someones whos got hot, it wasnt tight by my standards but certainly wasnt loose.
    I have to say Windows operating system is just utter pants.
    I will report back after having a go at the coding.
  6. Re: Some help needed with park brake problem, VCDS log file
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Next time when you don’t know or u’r not sure about something, just ask us maybe we can help you. Never use another tool for the brakes besides vcds. Generaly speaking what you did is very wrong. Perform the output test of the brakes and everything will be fine. Your car has to know min and max of the brakes. You will teach it with the output test. Code the battery with the same coding you had on the old one.
  7. Re: Some help needed with park brake problem, VCDS log file
    May 2008
    40 Post(s)
    VCDS will not talk to section/address 61 battery regul, any ideas? keeps saying controller not found.
    Pretty sure I did the output tests the other day can remember it saying 10mm or something like that one way and something the other way, it worked so didnt pay much attention.
    Shows Amps powering it and out pretty much the same each side.
  8. Re: Some help needed with park brake problem, VCDS log file
    May 2008
    40 Post(s)
    Can anyone tell me the location of the controller 61 as google seems to suggest if not found by VCDS its because the car doesnt have one fitted, so would like to do a physical check?
    Just found this on VCDS Wiki,[61] - Battery Regulation
    Note: Facelift models don't have an actual 61-Battery Manager but instead have the battery management as a slave under the CAN-Gateway. See the 19-CAN-Gateway section for detail
  9. Some help needed with park brake problem, VCDS log file
    Jul 2017
    Vigo di fassa italy
    13 Post(s)
    Near the battery you have a black box. Watch the cables from the battery to it.
  10. Re: Some help needed with park brake problem, VCDS log file
    May 2008
    40 Post(s)
    Battery coded under address 19 can gateway/long adaptation/channel 04/battery id.
    According to the yank forums you can fit an aftermarket battery of the same power as the one being replaced and just change one of the digits in the existing battery coding to tell the car its got a new battery and to learn it.
  1. rear door error code VCDS keyless entry problem help needed
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-01-2015, 06:11 PM
  2. Please Help Help needed Brake problem
    By sacha35 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-11-2014, 09:56 AM
  3. Passat B6 (3C) Rear Brake pad change - VCDS problem
    By dmcentire in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-04-2012, 06:50 PM
  4. Help needed with Park Brake/Auto Hold
    By mikecb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-11-2008, 01:21 PM
  5. brake problem - advice needed!
    By nik_codling in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 08:53 PM
