Thread: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
Results 1 to 8 of 8
  1. Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    Jan 2009
    Nuneaton England
    6 Post(s)
    Tick over is erratic from 850rpm down to 300ropm back to 850 then 0 and cuts out, not sure if this is related to the hot start?
    Fault codes present are
    4074 temperature sensor – gauge on dash works ok
    4142 RPM sensor no signal – if this was the case would it run at all?
    Cleared codes and ran OK this evening, starting from hot and I noticed the tick over is a little erratic but nothing like before
    Sometime when you stop at a junction it just cuts out. Butbeing hot it will not start unless I leave it for about 10/15 minutes, samething happens if I drive it for 10/15 minutes then stop it lock it go shop backto car, within a few minutes and all it does is turn over and over. If I leaveit 10/15 minutes it starts up OK
    Any ideas/help appreciated
  2. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    1840 Post(s)
    The rpm sensors fail when they get hot and then start working again when they cool, this is the usual way they fail, The temp sender is a dual NTC unit where one side feeds the dash and the other feeds the ECU.
  3. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    Jan 2009
    Nuneaton England
    6 Post(s)
    Brilliant thanks Crasher where is the RPM sensor located, do I have to go to Audi for one and is RPM sensor the name they will know it by?
  4. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    Feb 2018
    Fife
    As per Crasher and for crankshaft (rpm) sensor get genuine one.
  5. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    1840 Post(s)
    It is through the block adjacent to the gearbox flange on the side towards the front of the car, below and to the cars left of the oil filter and it points towards a 60-2 impulse rotor bolted to the back of the number 5 main bearing web of the crank. It is held to the block with a single M6 hex cap bolt which requires a 5-mm hex key.
  6. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    Jan 2009
    Nuneaton England
    6 Post(s)
    I will ring Audi tomorrow (Monday) thanks
  7. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All,
    Sorry for the late reply rang Audi obtained Crank sensor (RPM) replaced. All is good car starts first time hot or cold thanks for the advice
  8. Re: Audi A3 1.8T AGU Engine Will not start when hot!! X reg 2000 year
    1840 Post(s)
    Excellent.
  1. Replies: 29
    Last Post: 14-06-2013, 12:02 AM
  2. Audi A6 2.5 V6 TDI year 2000
    By anarack in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-03-2012, 10:01 AM
  3. Engine jerk Passat B5 1.8T Year 2000
    By tjompen1968 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2009, 07:53 PM
  4. Engine check light! YEar 2000 1.8T beetle
    By adeline_lkm in forum Beetle 2000-
    Last Post: 07-02-2009, 04:24 PM
  5. Question Polo Match 1.4 Year 2000 - Engine code?
    By dmsmart in forum Polo - Derby - Lupo - Fox
    Last Post: 24-01-2009, 10:27 PM
