Thread: Rear interior light stopped working?
  1. Rear interior light stopped working?
    Feb 2018
    West Yorkshire
    Everything was working good until I started changing the interior lights to LED's.
    I was changing the rear interior lights to LED's, but the middle socket would not hold the LED bulb, I squeezed the connections that holds the bulb and the bulb would fit slightly better, better than before.
    I opened the car door and the LED bulb slightly moved out of place causing the bulb to go on and off as it wasn't getting a proper connection. I now removed that bulb.
    Now I've realised when I open my car doors the rear interior light doesn't come on. But if I press the buttons to turn it on, it turns on.
    Anybody knows what could've happened?
    I've tried fitting the factory bulbs but it still does the same thing.
  2. Re: Rear interior light stopped working?
    Feb 2016
    manchester,uk
    12 Post(s)
    you may broken the connection while you were forcing the bulb in also check fuse.
  3. Re: Rear interior light stopped working?
    Feb 2018
    West Yorkshire
    Quote Originally Posted by f927 View Post
    Can the connection be fixed? Or will I have to buy a whole new rear interior light.
    Also which fuse am I looking for. I've looked all over google trying to find anything related to interior lights and I can't find a thing.
  4. Re: Rear interior light stopped working?
    Feb 2016
    manchester,uk
    12 Post(s)
    I dont know mate if it can be fixed.When you move the lever and the light comes ON are you able to see the contact made on the fitting ?. I would play with the fitting,try to make some sense out of it before buying,second hand will do as well.As for the fuse check in the hand book.
  5. Re: Rear interior light stopped working?
    Feb 2018
    West Yorkshire
    Tbh the middle bulb won't light up now, so am guessing I broke the connection :/
    But I still don't see why the left and right bulb won't light up when doors open.
  6. Re: Rear interior light stopped working?
    Feb 2016
    manchester,uk
    12 Post(s)
    check all bulbs that they are good if fitting are easily to take off ,check with a voltmeter on the plug if there is supply,if not check fuse.
  1. Replies: 6
    Last Post: 20-11-2018, 02:52 PM
  2. Rear Brake light on boot stopped working??!!
    By Muff666 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-06-2013, 10:31 PM
  3. Rear wiper stopped working
    By mlance in forum Golf MK5 - 2004 - 2009
    Last Post: 25-10-2008, 05:11 PM
  4. Rear Fog Lamp stopped working T4
    By BedfordBluesman in forum Touran - Sharan - Caravelle
    Last Post: 10-12-2007, 08:33 PM
  5. Rear Wiper stopped working
    By Slur in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2007, 03:38 PM
