Thread: Whistling noise coming from my turbo
  1. Whistling noise coming from my turbo
    Feb 2018
    North Yorkshire
    Can someone give me any advice on what to do with my turbo, I have a pd130 and the turbo is making a constant whistle noise it’s gotten louder over the past week, someone mentioned a bearing in the turbo that will be on its way out, I’ve checked the pipes and I can’t see no splits, any help would be much appreciated
  2. Re: Whistling noise coming from my turbo
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    If you're sure its no an air leak and you want to check the turbine shaft bearing for play you can get to it from inside the OS wheel arch once you get the liner out the way or from underneath if you can get it up high enough. Remove the intake pipe and spin the shaft by hand, check for lift ( radial play) and float (axial) if you can detect more than a smidge it is knackered. you might notice that the impeller has been contacting the compressor casing, the impeller blades will be worn down and you might be able to make it contact the casing if radial play is excessive. If this is the case, remove it and send away for refurb.
  3. Re: Whistling noise coming from my turbo
    Feb 2018
    North Yorkshire
    Thankyou il give that a go
  1. Question Whistling noise after new egr fitted. Turbo?
    By ledonster in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-07-2017, 07:30 AM
  2. Turbo whistling noise???
    By jasw in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-02-2017, 12:57 PM
  3. Turbo whistling and slight dump noise....
    By Sebseb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-11-2013, 04:27 PM
  4. Whistling noise coming from my Audi A6 2.5 TDI
    By Roland spiller in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-10-2010, 08:56 PM
  5. Question Turbo Whistling Noise
    By P4LI in forum Golf MK4 - 1999 - 2004
    Last Post: 08-10-2010, 04:31 PM
