Thread: Audi A4 B5 Throttle responsiveness .
Results 1 to 8 of 8
  1. Audi A4 B5 Throttle responsiveness .
    Jun 2008
    Is there a way I can make the throttle on my 96' A4 1.8 more responsive?.
    I feel like it's too easy to stall it and it requires quite a bit of throttle, which in turn is a bit slow to react.
    Any way I can adjust this? (have vag-com if that helps).
  2. Re: Audi A4 B5 Throttle responsiveness .
    Jan 2009
    Nuneaton England
    6 Post(s)
    Are there any fault codes?
  3. Re: Audi A4 B5 Throttle responsiveness .
    1840 Post(s)
    Check the operation of the inlet manifold variable length flap, the operating arm snaps and makes the engine unresponsive, presumably this is an ADR code unit?
  4. Re: Audi A4 B5 Throttle responsiveness .
    Jun 2008
    Quote Originally Posted by mumutley View Post
    I've had an 00561 15-00 "mixture adaptation limit (add) not reached error code from time to time.
  5. Re: Audi A4 B5 Throttle responsiveness .
    Jun 2008
    Yes, it's and ADR engine.
    How do I check/fix this?.
  6. Re: Audi A4 B5 Throttle responsiveness .
    Mar 2016
    Minervois, France
    53 Post(s)
    MacBain. Search engines are your friends!
    Here is the response to your question which Crasher posted 9 years ago!
    How To Maximise engine performance audi a4 b5 1.8 20valve engine - non turbo
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  7. Re: Audi A4 B5 Throttle responsiveness .
    1840 Post(s)
    Quote Originally Posted by FrenchAudi View Post
    Forgot all about that, I have written so much ******** it is lost in time...
  8. Re: Audi A4 B5 Throttle responsiveness .
    Jun 2008
    Thanks. Unfortunately the flap is not located like that on my engine.Any idea?.
  1. Audi Q7 throttle body
    By Imran786 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 13-03-2016, 11:50 PM
  2. Replies: 0
    Last Post: 29-10-2015, 12:52 PM
  3. Help Audi A4 1.9 DTI with intermittent throttle
    By glorybee in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-10-2010, 09:53 AM
  4. Audi A4 Throttle ECU problem
    By Tucker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2008, 01:47 AM
  5. throttle responsiveness
    By nibbzy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-04-2007, 02:32 PM
