Thread: 2007 mk5 1.4 radiator fan running after car is off
  1. 2007 mk5 1.4 radiator fan running after car is off
    Jul 2010
    Bradford, West Yorkshire
    right guys,
    have a customers golf 1.4 in the garage, the radiator fan is coming on full speed when the key is removed from the ignition, it is working as it should when the key is back in.
    no fault codes and live data is showing all temperatures are normal.
    we have replaced the complete fan with one we had at the garage and its still the same.
    any ideas on this guys
  2. Re: 2007 mk5 1.4 radiator fan running after car is off
    Jul 2010
    will quickly update this.
    after further diagnostics it turned out to be the engine bay fuse box full of water.
    replaced this and all is good.
  3. Re: 2007 mk5 1.4 radiator fan running after car is off
    1840 Post(s)
    I had the fan going nuts yesterday on a Golf 5 SDI when the ignition was on, this is usually a faulty fan pack but in this case it turned out to be the outside temperature sender had been cut off and it was saying the car was at 132 degrees so the fan came on to try and cool it.... I shoved a 4K Ohm resistor across the wires which made the gauge read 8 degrees and it shut the fan up, car is a complete shed.
  4. Re: 2007 mk5 1.4 radiator fan running after car is off
    Jul 2010
    Yh mate ive seen that before. The mk5s are really starting to show their age. Still to see a mint one come in
  1. Radiator fan running with aircon
    By DOILY in forum Polo - Derby - Lupo - Fox
    Last Post: 18-07-2017, 11:53 AM
  2. Question 2007 Jetta 2.0 TDI Radiator Fan problem
    By PaulBn in forum Jetta MK3 - 2005 - 2013
    Last Post: 09-09-2016, 12:11 PM
  3. Radiator fan always running??
    By Chipped2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2013, 12:11 AM
  4. Polo 9N (2007) 1.4 Radiator change.
    By Col in forum Polo - Derby - Lupo - Fox
    Last Post: 22-09-2012, 02:12 PM
  5. A6 2.0 TDI continuously running radiator fan
    By stafkemp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-01-2010, 09:15 AM
