Thread: 2000 rpm?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: 2000 rpm?
    #11
    Jan 2013
    Liverpool
    Quote Originally Posted by mcbane21 View Post
    Reading around and this all points to the heater matrix pipes.
    According to another forum, Heater pipes going into the matrix were rubbing on a square edged piece of plastic and wedging a piece of rubber in the gap appears to stop the noise.
    No pictures unfortunately.
    could you please let me know the name of the another forum mention this issue? thanks
  2. Re: 2000 rpm?
    #12
    Jan 2013
    Liverpool
    Quote Originally Posted by Mintyjim View Post
    I had this on mine. Heater matrix, easily accessed from the passenger side by removing the big plastic trim on the side of the "transmission tunnel" you'll see the aluminium heater matrix, the feeds are probably touching, gently move them apart. I also added some foam for extra NVH properties!
    thank you for your information. my B8 150ps saloon suffer the same issue. Do you think the owner can solve it DIY? "big plastic trim on the side of the "transmission tunnel" what is that position? thanks.
  3. Re: 2000 rpm?
    #13
    Jan 2013
    Liverpool
    very nice solution from yours. how much you pay to dealer regarding this issue. Is it a complex work? or DIY possible?
  4. Re: 2000 rpm?
    #14
    Nov 2017
    Cambridgeshire
    10 Post(s)
    Ours has been doing this since we’ve owned it (20k and 20 months ago) but after reading this I asked the dealer to look into the issue when I was having the car serviced yesterday - when I handed the car over the service guy said he wasn’t aware of it but they would do a check for technical bulletins.
    They rang in the afternoon to confirm the service had been done and there was indeed a VW bulletin for this to be undertaken if the customer mentions it (rather than it being a recall or automatically undertaken) and that it would be covered by VW if we paid for a diagnosis (£60), I pointed out the car is on a 2 year extended warranty until the end of October so it was FOC but for those out of warranty it would be a £60 repair.
    The wording on my service sheet is;
    Code ‘51 LAB’ carried out fix as per technical information to rectify customer issue of heater matrix pipe vibrating. Now all OK’
    I don’t know if this is Vindis wording and coding or VW but hopefully it can help others. I can confirm the issue was completely absent on the journey home.
    That’s my second free service and the benefit of my 2 year warranty, more than a happy with that!
    2015 Passat B8 2.0TDi 150 GT Estate in Deep Black
    2005 A2 1.4TDi 75 SE in Silver
  5. Re: 2000 rpm?
    #15
    Jan 2013
    Liverpool
    Thank you very much for your information. it is very helpful. I will try to contact with vw and update here any progress.
    we are very similar 2015 Passat B8 2.0TDi 150 GT slaoon in blue
  6. Re: 2000 rpm?
    #16
    Torpoint, UK
    Iíve applied the fix myself. Took 10 minutes and what a difference.
    My car went in for a service and I asked the dealership to have a look explaining that there was even a TSB.
    Needless to say they couldnít find any issues despite test driving the car.
    After some more searching, I found a description of where to look.
    Thereís a side panel down in the passenger footwell (RHD Cars) thatís attached to the centre console. This is held on with a torx screw.
    Remove the screw, give the panel a light tug and if you look inside to the left, youíll see two pipes. Push these aside and thatíll cure the rattle.
    They were very close with no bracket separating them. Poor design there.
  7. Re: 2000 rpm?
    #17
    Jan 2013
    Liverpool
    Hi friend, would you please mark on your photos, which ' two pipes' you mentioned.
    my vw specialist also open this panel and add a piece of Buffer foam between heater matrix pipes, but no fix
    vw passat B8 2000rpm vibration noise at 30mph cause by loose heater matrix pipes - YouTube
    finally, I found the answer from vw german forum
    https://www.motor-talk.de/forum/uebe...r-login-header
    one cable tie could fix!
  1. vw t4 2.5 L 2000
    By visari in forum The Commercial Range
    Last Post: 06-11-2016, 08:06 AM
  2. 2000 s6 rns-d
    By Jimes256 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2013, 09:10 PM
  3. Question Sat Nav A4 2000
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-10-2012, 06:08 PM
  4. 2000 x reg 2.0 gti
    By dtomlinson in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2010, 11:42 PM
  5. 2.5 tdi AFB no rev above 2000
    By aaman100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-03-2010, 08:30 PM
