Thread: 2000 rpm?
Results 1 to 10 of 17
  1. 2000 rpm?
    Jul 2017
    newcastle
    Had my 15 plate passat b8 estate gt for 6 months now and love it, however i've noticed when at 2000 rpm is any gear i hear what sounds like a vibration coming from behind the dash somewhere in the centre. Its not the actual dash vibrating itself sounds like its coming from the engine bay, but hen outside the car you can't hear it only when inside the car driving?! It's really annoying while driving at 70 and you put your foot down to overtake!
    Anyone had anything similar? coming to the end of its warranty. :-(
    Thanks in advance guys!
  2. Re: 2000 rpm?
    1840 Post(s)
    It is quite often the engine cover or even just the badge but sometimes a lose air cleaner top.
  3. Re: 2000 rpm?
    Torpoint, UK
    Quote Originally Posted by budd3n View Post
    Did you ever solve the problem? I’ve got the same issue too.
    I’d like to avoid taking it to a dealer if possible.
  4. Re: 2000 rpm?
    Jul 2015
    GB
    I have the same problem too. I had a long argument with VW over a few weeks when I tried to convince them it existed. They refused to investigate under warranty. It’s now out of warranty and I’d love to find out how to fix it!
  5. Re: 2000 rpm?
    Aug 2007
    Hampshire
    Not sure if it’s the same problem but my from new 2015 GT saloon had a similar noise / vibration at 2000 rpm coming from the area you are describing. My dealer worked out that is was a loose pipe and clip(s) used for the heater matrix or something in the engine bay. Sorted in the first year and haven’t had any recurrence since
  6. Re: 2000 rpm?
    1840 Post(s)
    On the 240 PS bi turbo there is a heat shield over the right hand inner CV boot which can crack and buzz, it should have been removed under a "quality improvement program" but the heater feed pipe issue is the most common reason on cars upto VIN wvwzzz3CzGE172650. There is a full TPI about the issue, 2042131/3
  7. Re: 2000 rpm?
    Torpoint, UK
    Reading around and this all points to the heater matrix pipes.
    According to another forum, Heater pipes going into the matrix were rubbing on a square edged piece of plastic and wedging a piece of rubber in the gap appears to stop the noise.
    No pictures unfortunately.
  8. Re: 2000 rpm?
    Aug 2007
    Hampshire
    That’s the thing! Glad we could help. As I said my dealer sorted it out very quickly. You should be able to get it fixed now
  9. Re: 2000 rpm?
    Nov 2016
    Cardigan
    6 Post(s)
    I had this on mine. Heater matrix, easily accessed from the passenger side by removing the big plastic trim on the side of the "transmission tunnel" you'll see the aluminium heater matrix, the feeds are probably touching, gently move them apart. I also added some foam for extra NVH properties!
  10. Re: 2000 rpm?
    Jun 2019
    Quote Originally Posted by mcbane21 View Post
    My nephew has the same issue.The moment I read it I called him
    He will say this at the shop, and hopefully they will resolve it
    Thanks guys!
  1. vw t4 2.5 L 2000
    By visari in forum The Commercial Range
    Last Post: 06-11-2016, 08:06 AM
  2. 2000 s6 rns-d
    By Jimes256 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-04-2013, 09:10 PM
  3. Question Sat Nav A4 2000
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-10-2012, 06:08 PM
  4. 2000 x reg 2.0 gti
    By dtomlinson in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2010, 11:42 PM
  5. 2.5 tdi AFB no rev above 2000
    By aaman100 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-03-2010, 08:30 PM
