Thread: A3 2.0 tdi issues
  1. A3 2.0 tdi issues
    Feb 2018
    Fernhill Heath, Worcester
    Have just replaced egr valve yet every 30miles coil light and limp mode occurs turn ignition off and its gone til next time. No fault codes are appearing but i cant live with it doing this. Any ideas??? Already spent fortune on car so cant keep affording to change parts.???
  2. Re: A3 2.0 tdi issues
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    What are you using to scan the car? if it is going into limp mode there should be a code logged. Also what year, engine code (PD or common rail) , mileage etc, would help.
  3. Re: A3 2.0 tdi issues
    108 Post(s)
    1816 Post(s)
    If it is going into limp mode and the coil light is on, your reader is missing the code.
  4. Re: A3 2.0 tdi issues
    Feb 2018
    Quote Originally Posted by Rob69 View Post
    I took it back to the garage that fitted new egr they did get a egr fault show again they kept it for few hrs then said see how that goes. Literally 10 miles down road happened again but they said no fault code showing again. Took it to another garage that pit it on their diagnostics machine and no code however its had coil light and idle few times.
    Its a 2010 got 135000 on clock. Its not a sport just standard diesel 2.0tdi.
  5. Re: A3 2.0 tdi issues
    Feb 2018
    Taken it back to garage who fitted egr and they got no fault code so i took it to a more modern garage they put their diagnostics on it and they got no code either yet the cars coil light and limp mode has happened at least 5 times.
  6. Re: A3 2.0 tdi issues
    108 Post(s)
    1816 Post(s)
    If the light is on a code is at home, you need to find someone with proper diagnostic equipment, not just generic ODDII.
  1. 01 1.8T few issues
    By fivepointnine in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 30-05-2015, 08:56 PM
  2. MPG Issues
    By DWaddell123 in forum Chat - Anything with wheels
    Last Post: 30-01-2015, 08:46 AM
  3. 3TDi starting issues/ dying issues
    By 20vcqdriver in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-05-2014, 10:01 AM
  4. my next two issues
    By carlos-1975 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-05-2010, 06:54 PM
  5. Air Con issues
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2007, 12:10 PM
