Thread: ABS Control Unit / Module - 2005 - Golf Plus GT - 2.0 TDI
  1. ABS Control Unit / Module - 2005 - Golf Plus GT - 2.0 TDI
    Nov 2016
    Burnham on Crouch
    Hoping someone can offer some advice. Our Golf has just failed its MOT as it had a ABS light on the dash, the garage are saying that it needs a new ABS control module, which they are saying will cost over £600 for the part alone. Wandering if this is an accurate price and if there are any other suggested options that we could consider. We thought about buying a second hand part, but the obvious risk would be that the part may be faulty and then I'd end paying the labor costs twice.
    Any suggestions or ideas would be very much appreciated
    Thanks in advance
  2. Re: ABS Control Unit / Module - 2005 - Golf Plus GT - 2.0 TDI
    Jan 2010
    southport
    Hi.
    I had the same issue on my 2000 A4.ABS light on the dash and the car wouldnt link up to vcds.I bought a second hand ABS contol unit, but i only changed the black module box. All worked fine straight away and onlt took about 25 mins to change out.The second hand unit cost me £80. Well worth it as a quick cheap fix.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  3. Re: ABS Control Unit / Module - 2005 - Golf Plus GT - 2.0 TDI
    1834 Post(s)
    Quote Originally Posted by caribsimon View Post
    That price does not make sense using VW genuine parts as the unit is available in three forms from VW depending on what fault you are dealing with, have they given you a fault code? Were the ABS and ESP lights on, just the ESP or just the ABS? The usual ESP versions ECU is £855.61, the full ABS unit is £1058.61 and the standard pump repair kit for the very common G201 faults is £303.52 so you need to clarify what the problem is.
  1. Reprogramming of Door module Control Unit Audi A6 TDI 2007
    By shawn2606 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-02-2015, 08:17 PM
  2. Electric window unit - control module
    By Benprice8784 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-12-2014, 12:38 PM
  3. Parking sensor control unit for allroad 2005 ltd edition tdi auto
    By garyizme in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-12-2012, 02:47 PM
  4. MK 4 Golf climate control unit
    By robbiep in forum Golf MK4 - 1999 - 2004
    Last Post: 04-10-2009, 11:27 PM
  5. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
