Thread: Help please! Centre arm rest, what options do I have?
  1. Help please! Centre arm rest, what options do I have?
    Jan 2018
    Hi, I've recently purchased a 2007 Q7 S Line and in the centre console I have this...
    Q1: What is this?
    Q2: What options do I have for media?
    Q3: Can I link my phone in here to play music and make calls?
    Thank you for any help.
  2. Re: Help please! Centre arm rest, what options do I have?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by m1kely View Post
    Q1: What is this?
    It looks to me like the baseplate for a Generation 2 or 3 phone cradle. Audi have stopped making these now, I think. The idea was you could buy a cradle to fit your phone, and it would charge the phone plus connect it to the MMI for making/receiving calls. For some phones it also connected the phone to the car's antenna too. As far as I'm aware it was just for calls though - not for music streaming. Does your car have bluetooth? Depending on the car's age, it might support bluetooth music streaming if so? Probably not if it's a 2007...
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Help please! Centre arm rest, what options do I have?
    Jan 2018
    Hey. thanks for the reply.
    When I press the TEL button, it says "TELEPHONE NOT INSTALLED" on the MMi. Is this something I can switch on in VAGCOM?
    I have noticed that there is a microphone installed in the overhead lighting area so it must have the hardware installed. I can't currently get into the hidden menu so I don't know how to check if it has bluetooth, I have an in dash 6 CD changer, it's a 2007 S Line. I imagine it would have Bluetooth hardware installed. Weather or not it has capability of music streaming or not I don't imagine it would. Is there anything I can plug into the MMi to stream music from the cloud through the MMi?
    Thanks for your help.
  4. Re: Help please! Centre arm rest, what options do I have?
    May 2009
    69 Post(s)
    It sounds like you just have the hard-wired connection from the phone cradle to the car, and no bluetooth. The microphone would be used if you had a phone in a cradle attached to the car.
    Does your car have AMI (Audi Music Interface)? On your car it would sit in the glovebox next to the CD changer. If you have that, you could connect an iPod/USB disk/thumb drive to the car and control it through the MMI. You could probably connect an A2DP streaming adaptor to it too if you wanted bluetooth streaming from a device in the car.
    If you don't have AMI you're stuck, though. You might want to look at getting it retrofitted. An alternative would be a Dension Gateway, which could give you AMI features and bluetooth telephone connection too.
    Cheers!
    MF.
  5. Re: Help please! Centre arm rest, what options do I have?
    Jan 2018
    That makes sense! Thanks.
    I doesn't have AMI, it has an in dash 6 CD changer so it looks like Gateway 500S BT (Dual FOT) is going to be my best option, I just hope there's room behind the dash to fix it safely. I'll let you know how it goes. Thanks for your help.
  6. Re: Help please! Centre arm rest, what options do I have?
    May 2009
    69 Post(s)
    Just as one final sanity check, if you start the car then search on your phone for bluetooth devices, do you see the car as a device your phone can connect to? If not, then you don't have bluetooth...
    Cheers!
    MF.
  7. Re: Help please! Centre arm rest, what options do I have?
    Jan 2018
    Nope. I’ve been trying to find ways to enable via VCDS but as of right now, I’ve been unable to find any options to change.
    At least I’ve managed to get video in motion working over 3mph.
  1. A4 B7 Centre Arm Rest Cup Holders??
    By Tricky_Dicky in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-02-2010, 07:09 PM
  2. Centre Arm rest!!
    By stusA3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-11-2009, 10:55 AM
  3. Centre Arm Rest
    By JohnyIre in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-09-2009, 12:39 PM
  4. Centre Arm Rest Latch ?
    By sbuk73 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-01-2008, 08:58 PM
  5. Centre arm Rest
    By rosco16 in forum Passat - Archive Topics
    Last Post: 18-05-2007, 09:55 PM
