Thread: Installing backup camera to RNS 510
  1. Installing backup camera to RNS 510
    Jul 2010
    Land's End
    Annoyingly, our new Passat B7 came without any parking cam or sensors. Is the camera an easy add-on to the RNS 510 head unit, or should I stick with a standard reversing sensor kit?
  2. Re: Installing backup camera to RNS 510
    1840 Post(s)
    I did one on a Golf 6 using a Kufatec harness, it drove me potty with the problems until we found that the plug was badly made and was not engaging in the head unit correctly without forcing it in but even then it still comes up blue screen sometimes or flickers and constantly leaves CAN system errors as it does not communicate properly.
  3. Re: Installing backup camera to RNS 510
    Jan 2009
    South Bucks UK
    I fitted one to my estate and the hardest hardware fitting part was getting cables through the rubber gaiters from the tailgate and into the roof lining. Apart from that it’s just trim removal and cable routing. You will need VCDS to programme it in. There are some versions out there that do not show the yellow lines moving with the steering. If that is important ensure you get one with the canbus cables to connect it.
  1. 2009 Audi A6 backup camera options
    By pomps74 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-08-2018, 01:05 PM
  2. Reverse Camera / Backup Camera stopped working - please help
    By A6-MO in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 07-04-2017, 03:32 PM
  3. Backup camera
    By Kelvin Johnson in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 03-05-2016, 03:08 PM
  4. Installing rear camera passat B6 estate
    By johnandrew70 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-02-2013, 11:54 PM
  5. RNS-E DVD Backup
    By buzzsaw in forum In Car Entertainment
    Last Post: 11-03-2011, 08:31 AM
