Thread: MK6 Golf Driver side door hesitant to open from in side.
  1. Exclamation MK6 Golf Driver side door hesitant to open from in side.
    Feb 2016
    manchester,uk
    12 Post(s)
    Hello,I have Golf MK6 12 PLATE 1.6 TDI. My driver side door is sticky when opening from in side. Im pulling on the lever but door feel jammed unless I give it nudge before it opens.
  2. Re: MK6 Golf Driver side door hesitant to open from in side.
    13 Post(s)
    317 Post(s)
    Lock unit failure on the Golf 6 is common, eventually you can't open the door at all and it becomes a sketch to change the lock unit.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  3. Re: MK6 Golf Driver side door hesitant to open from in side.
    Feb 2016
    manchester,uk
    12 Post(s)
    thank you Crasher.
    I have had a look,all the pop rivets. Im having similar issue with me daughter honda civic back boot not opening,powered it up,boot opens but wont stop clicking,Im working on that.
  4. Re: MK6 Golf Driver side door hesitant to open from in side.
    13 Post(s)
    317 Post(s)
    If you had bought a 2 door they have an access cover but the four door means drilling out 11 pop rivets. VW say that these can be replaced with the later attachment method of push through plastic rivets (part number 5K0 837 975 A @ £1.62 each) but I am suspicious of this method as the note in the VW instructions make absolutely no sense, unless I am being thick, quite possible!
    Remember that the door glass clamps are left hand thread
  1. Audi driver side door wonít open from inside- need locksmith advise
    By francescoherrer in forum Chat - Anything with wheels
    Last Post: 15-03-2016, 10:11 AM
  2. Driver side rear door won't open from outside
    By apache24uk in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2016, 11:19 AM
  3. mk 4 golf passenger side door wont open
    By jhueym in forum Golf MK4 - 1999 - 2004
    Last Post: 04-11-2009, 06:37 PM
  4. Question Driver side "door open switch" location???
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2009, 12:11 PM
  5. Golf - Window dropped into driver's side door!
    By Rachel in forum Golf MK4 - 1999 - 2004
    Last Post: 13-11-2007, 09:29 PM
