Thread: Clutch pressure plate?
  1. Clutch pressure plate?
    Jan 2018
    Littlehampton
    Good morning all!
    Right so, my little Audi 1.8t (aum engine code) seems to have developed an issue with the clutch.
    Basically I have a very light clutch pedal and can't get the thing into gear, have checked slave and master cylinders for leaks and nothing, bled the system and still no clutch, so I'm looking to undertake the gearbox removal to change the clutch as I believe the pressure plate has collapsed. But before I do just wanted to get a group of experts advice first! For few days before clutch stopped working the bite point was very very low, and suddenly I was finding it hard to get into gear before I lost the ability to get it in gear completely... right now it's making an almighty noise unless I rest my foot on the clutch pedal (I thing it's the release bearing just touching the pressure plate)
    What I want to know is what's the chances that it's not the clutch? Are the master or slave cylinders known for failing without leaks? I've kinda drawn out the dmf as there's still drive and no thumping around in the bell housing.
    Any help would be appreciated!
  2. Re: Clutch pressure plate?
    Feb 2016
    manchester,uk
    14 Post(s)
    while engine is off,if all gears are selected,its clutch issue.
  3. Re: Clutch pressure plate?
    Jan 2009
    Nuneaton England
    6 Post(s)
    From personal experience when doing a clutch I now a days replace the complete unit, flywheel, pressure plate, friction please and release bearing.
    I learnt the lesson years ago save money just do the pressure plate and a few weeks later I was doing the job all over again!!
  4. Re: Clutch pressure plate?
    Feb 2018
    Fife
    Sounds potentially like the release bearing has worn its way through the clutch cover spring/ fingers. If you are getting lots of noise its obviously an issue internally and not hydraulics..
  1. Changing Clutch/Dmf/pressure plate + Cambelt on 2.0L
    By gunner786 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 03-02-2016, 01:21 PM
  2. Question Pressure Plate Broken Up GT TDI
    By Graham24 in forum Golf MK6 - 2009 - 2013
    Last Post: 27-08-2015, 09:12 AM
  3. Please Help pressure plate
    By pimped..a4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-07-2011, 06:31 PM
  4. Please Help Polo Clutch Pressure Plate?
    By 5StarG in forum Polo - Derby - Lupo - Fox
    Last Post: 07-05-2009, 10:43 AM
  5. Strange wear on pressure plate
    By steve_m in forum Golf MK5 - 2004 - 2009
    Last Post: 22-10-2008, 09:17 PM
