Thread: No boost - 16621 error - Any ideas?
  1. No boost - 16621 error - Any ideas?
    Jan 2017
    Hi guys
    My friend has an Audi a3 Sportback 2005 1.9 TDI 103BHP and she has had a sudden loss of power. The car seems to drive like the turbo is not spooling but stills gets up some speed, it just takes a while!
    We scanned the car and got the following results:
    1 Fault Found:
    16621 - Manifold Pressure / Boost Sensor (G31)
    P0237 - 000 - Signal too Low
    Freeze Frame:
    RPM: 798 /min
    Torque: 30.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000000
    Absolute Pres.: 1081.2 mbar
    Absolute Pres.: 2182.8 mbar
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 4
    Mileage: 268134 km
    Time Indication: 0
    Date: 2017.12.22
    Time: 14:29:33
    Freeze Frame:
    Temperature: 12.0°C
    Voltage: 14.40 V
    RPM: 1850 /min
    Load: 30.0 %
    Load: 25.0 %
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 253
    Mileage: 268961 km
    Time Indication: 0
    Date: 2018.01.09
    Time: 15:53:00
    Freeze Frame:
    Temperature: 8.5°C
    Voltage: 14.50 V
    RPM: 1850 /min
    Load: 0.0 %
    Load: 9.0 %
    I have done a log of the car on idle and flicked the throttle a little to see if the MAP was doing anything but i don't know how to read the logs all that well so if someone could tell me if they think the MAP is functioning that would be great!
    LOG: LOG-01-007-010-011.zip
    Any ideas would be very helpful.
    Thanks!
    Jamie
  2. Re: No boost - 16621 error - Any ideas?
    1834 Post(s)
    Your boost pressure is stuck on 2193mBar which suggests a failed MAP/IAT (AKA "Thrust" sensor) and I have seen these stick.
  3. Re: No boost - 16621 error - Any ideas?
    Jan 2017
    Hi Guys,
    I've changed the MAP unit on the car for her however we are still getting the same problem. The error code will not go away!
    I put a multi-meter across the pins and got the following:
    1 - Ground?
    2 - approx 4.9V
    3 - nothing
    4 - approx 5-5.1V
    Could anyone let me know if getting nothing on pin 3 is normal? Or maybe this is the part of the problem and the reason for the code?
    Since changing the sensor i have done another scan for faults and got the following:
    2 Faults Found:
    18000 - Altitude Sensor / Boost Pressure Sensor
    P1592 - 000 - Implausible Correlation
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 00000100
    Absolute Pres.: 999.6 mbar
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.39 V
    Bin. Bits: 00000100
    Absolute Pres.: 183.6 mbar
    Readiness: 0 0 1 1 1
    Any help would be really appreciated! I also found out her engine code is: BKC
    Thanks,
    Jamie
  4. Re: No boost - 16621 error - Any ideas?
    May 2018
    Italy
    hi, i have the same problem on my audi a3 engine BCK 1.9 TDI. Did you find a solution? Reading online could be some electrical wire from the MAP sensor... I've already tried to change all the sensors
  5. Re: No boost - 16621 error - Any ideas?
    1834 Post(s)
    There is a harness repair set available from VW under the part number 1KD 971 658
  1. N75 error code AHU tdi, no boost
    By rjc98rjc98 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-03-2017, 10:40 AM
  2. Please Help A4 2.0TDI EGR error after remapping ECU...any ideas???
    By tuffguy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-12-2011, 10:08 AM
  3. vag com error code any ideas
    By MCCLATCHIE in forum VCDS - General Questions
    Last Post: 05-06-2010, 09:17 PM
  4. Vag-Com error codes, any ideas for fix?
    By abbeyhouse in forum Archive posts
    Last Post: 05-06-2007, 11:30 PM
  5. mk4 gti 2.0, 3 error codes, lean trim, ideas?
    By leckford in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2007, 11:57 PM
