Thread: TDI engine noise ?
Results 1 to 10 of 10
  1. TDI engine noise ?
    Thom89 Guest
    Hi all,
    I recently picked up a Golf TDI and I get this noise sometimes very faint but I can hear it when inside but not in the engine or if it is I can't hear it.. The sound clip is when my phone is sitting on the middle of the dash above the middle vents so you can hear it better than if I hold the phone. This noise is still present when the radio/fans are off
    Edit: Only can hear it on idle and goes away with slight revs or the engine drowns out the sound
    Zippyshare.com
    Thanks for any input
  2. Re: TDI engine noise ?
    1840 Post(s)
    Do you know if the car has had the emissions recall carried out? This is well known to increase diesel noise, in fact the sub routine in the program that caused the kerfuffle was called the noise reduction routine.
  3. Re: TDI engine noise ?
    Thom89 Guest
    Yes the update was applied to this car..not sure if you listened to the clip but it sounds like an intermittent rubbing noise
  4. Re: TDI engine noise ?
    1840 Post(s)
    It is very difficult to get a feel for what it is from a recording.
  5. Re: TDI engine noise ?
    Thom89 Guest
    Very true just in hope that someone may have had a similar issue with a similar noise
    Sent from my MHA-L09 using Tapatalk
  6. Re: TDI engine noise ?
    Thom89 Guest
    Have narrowed it down to either the heater matrix is at fault.. or the AC compressor.. noise comes from the heater matrix area in the engine bay but when I press the AC on button the noise goes away
  7. Re: TDI engine noise ?
    1840 Post(s)
    AC "ON" and the noise goes away?
  8. Re: TDI engine noise ?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I had similar on relatives 2013 yeti tdi, ac compressor pulley drive plate rivets were loose, there was a lot of metallic rust in the pulley area and noise stopped or at least changed when the ac kicked in. He got a new comp fitted under warranty thankfully.
  9. Re: TDI engine noise ?
    Thom89 Guest
    Yes when I turn the ac on the noise I hear goes away
  10. Re: TDI engine noise ?
    Thom89 Guest
    Quote Originally Posted by Rob69 View Post
    Ah thanks for that sounds very similar
  1. V5 20v engine noise on chain side of engine
    By craig-v5-20v in forum Toledo
    Last Post: 09-01-2015, 11:33 AM
  2. Question Golf tdi ALH engine... Engine knocking noise. Help wanted
    By Onionss74 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2014, 08:29 PM
  3. Question Audi A4 3.0 Conv 2004 - Engine whining noise from front of engine.
    By alancobra in forum New Member Introductions
    Last Post: 09-01-2013, 06:10 PM
  4. Engine/Transmission - Vibration/Noise at certain engine revs
    By audikid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-08-2012, 09:32 AM
  5. engine noise - pulleys or bearing noise
    By johnmccracken in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-08-2011, 02:28 PM
