Thread: limp mode problem
Results 11 to 20 of 21
  1. Re: limp mode problem
    Forres Scotland
    so been to local garage and have come up with these fault codes.
    16618 -
    engine boost condition - limit exceeded. Hose connection wiring TC wastage, regulating valve TC wastage.
    16785 -
    EGR Recirculation flow. - Hose leak/blockage basic setting not carried out. EGR valve/solenoid.
    any info on what these mean or advice on how to fix would be most welcome.
  2. Re: limp mode problem
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    They're basically the same codes you posted in #1 , at the end of the day you need to check for vacuum leaks and get better diagnostics done not just generic OBDII codes. N18 solenoid for EGR valve, N75 solenoid for turbo VNT actuator, my money is on split or porous vacuum hose or the VNT guide vanes being sticky but you won't know until you diagnose it, or fix it by chance either changing the turbo or finding a vacuum leak or sticking solenoid. You're already into this for the cost of a probably unnecessary EGR valve.
  3. Re: limp mode problem
    1836 Post(s)
    You need to check the vacuum control system for leaks but the overboost code is probably not linked as a vacuum system leak normally causes an underboost code.
  4. Re: limp mode problem
    Forres Scotland
    ok thanks for your reply will try find leaking hose
  5. Re: limp mode problem
    Apr 2016
    london
    overboost condition is usually related to blocked vgt {variable geometry}
  6. Re: limp mode problem
    1836 Post(s)
    Really?.....
  7. Re: limp mode problem
    #17
    Jul 2019
    Usually broken vaccum hose, N75 and sticky vanes. I'v had all three. @Crasher, how can the EGR cause overboost?
  8. Re: limp mode problem
    #18
    Forres Scotland
    thanks for your reply, will try and find broken hose.
  9. Re: limp mode problem
    #19
    1836 Post(s)
    Quote Originally Posted by A6C5V6TDi View Post
    It can't, why? A vacuum leak in the system can cause underboost but not overboost.
  10. Re: limp mode problem
    #20
    Jul 2019
    I thought you said EGR said EGR can cause over/under boost problems. My bad.
  1. Overboost and Limp Mode problem solved.
    By Big G. in forum Golf MK4 - 1999 - 2004
    Last Post: 15-08-2019, 08:44 PM
  2. Question Unknown Problem!! Limp Mode? Please Help
    By SB_MK5Golf in forum Golf MK5 - 2004 - 2009
    Last Post: 02-07-2017, 12:11 AM
  3. 130tdi limp mode problem.
    By FARA in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-11-2009, 08:53 PM
  4. Transporter T4 limp mode problem
    By andrew pearce in forum The Commercial Range
    Last Post: 26-09-2009, 09:13 AM
  5. Tdi limp mode/N75 problem?
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2008, 09:09 AM
