Thread: limp mode problem
Results 1 to 10 of 14
  1. limp mode problem
    Forres Scotland
    Hi, have problem with my vw golf 2ltr tdi mk5 golf BKD engine.
    started going into limp mode while overtaking, have read codes on my hand held scanner and come up with,
    P0401- exhaust gas recirculation flow insufficient.
    P0234 - turbocharger overboost condition.
    can anyone help me sort this problem??
  2. Re: limp mode problem
    Nov 2010
    Shetland & S.Tyneside
    99 Post(s)
    It needs a full scan and more diagnostics, could be the turbo vnt sticking. Try Kennys vw & audi specialists in Inverness.
  3. Re: limp mode problem
    Jan 2018
    Stourbridge
    Try changing the engine oil to a top grade oil. this did happen to me on an A6 2.7 with the overboost message, turned out I had the wrong grade oil in the engine. Always use Shell Helix professional or Castrol nowadays
  4. Re: limp mode problem
    16 Post(s)
    397 Post(s)
    You could have a vacuum control system problem there caused by a split hose or valve leaking or a faulty EGR valve and a dirty turbo, P codes alone can't tell you the full story, the outputs and measured blocks for the components need to be checked. You could go and fit a new EGR valve and turbo only to find out it is a simply vacuum leak.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  5. Re: limp mode problem
    Forres Scotland
    thanks for info Rob will check them out
  6. Re: limp mode problem
    Forres Scotland
    Hi Crasher, thanks for your comments.
    Have had the over boost code coming up since had car (8years), just turn ignition off then on again and goes no problem.
    Went to garage today and they think might be EGR Valve dirty or sticking, recommend new one??
    Where to look for split hose??
  7. Re: limp mode problem
    Jul 2007
    glasgow
    34 Post(s)
    I would wait for the fault to develop, slit hoses are cheapest option at the moment
  8. Re: limp mode problem
    Forres Scotland
    removed EGR valve at weekend and cleaned it. was able to push piston up and down with no problem.
    Took car for a drive and once got over 60mph it went back into limp mode and same faults coming up.
    can anyone tell me which hoses to check for slits or cuts ??
  9. Re: limp mode problem
    16 Post(s)
    397 Post(s)
    Did you check the EGR valve diaphragm to make sure it was not punctured? To check for a vacuum system leak, firstly apply a vacuum to the source feed pipe of the servo line and see if you can pull a constant stream of air. Alternativlly you can just suck on the small vacuum hose but this will not eliminate the servo and its lines as a source of any vacuum problem. Quite often we find the valve block unit is leaking internally.
  10. Re: limp mode problem
    Forres Scotland
    update, fitted new EGR Valve and problem still exists. any advise on which vacuum pipes to check would be appreciated. many thanks
  1. Question Unknown Problem!! Limp Mode? Please Help
    By SB_MK5Golf in forum Golf MK5 - 2004 - 2009
    Last Post: 02-07-2017, 12:11 AM
  2. Overboost and Limp Mode problem solved.
    By Big G. in forum Golf MK4 - 1999 - 2004
    Last Post: 18-03-2011, 01:43 PM
  3. 130tdi limp mode problem.
    By FARA in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-11-2009, 08:53 PM
  4. Transporter T4 limp mode problem
    By andrew pearce in forum The Commercial Range
    Last Post: 26-09-2009, 09:13 AM
  5. Tdi limp mode/N75 problem?
    By scotty33 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2008, 09:09 AM
