Thread: Oil pressure warning light. Not sure what to do..
  1. Oil pressure warning light. Not sure what to do..
    Jul 2016
    uk
    Hello folks. I own an a4 2.0 tfsi quattro, with a BWE engine.
    About 6 months ago I was driving home from a trip to the coast when the i got the oil pressure warning light. I couldn't pull over immediately as I was on a busy road and had the whole family in the car about a mile down the road just as i reached a lay by I lost all power and just managed to pull the car in. I had to have the car recovered and put on my drive where it has sat up until now untouched. (long story)
    Today I got someone around to plug a machine in to it and see what codes it threw up. before deciding what to do with it next.
    Here are the codes.
    P2261 - P3087 - P2181 - P0011 - P1602.
    From looking online most of those are possibly to do with it being stood for so long. I've read its a fault with the balance shaft pin and normally once the oil pressure light comes on and you continue driving the engine is goosed. So I thought I'd just turn the key to see what happens. It fired up, sounded very tappy on the top end, but it has been stood for a long time. I turned it back off straight away, but it fired up. Really not sure what to do next, I've lost a fortune on this car if it's knackered, i'd only just had the clutch and fly wheel done about a couple of weeks before it happened plus other things. Thinking of sending it off to audi but would like to know if there's any other things I could check myself before throwing any more cash into it
    Thanks.
  2. Re: Oil pressure warning light. Not sure what to do..
    May 2012
    Everywhere
    308 Post(s)
  3. Re: Oil pressure warning light. Not sure what to do..
    1840 Post(s)
    P0011 is due to no oil pressure and others suggest the turbo has been damaged which is normal in this situation. It would be worth putting in a genuine exchange engine (£6K plus VAT plus labour) and recon turbo as petrol engines EU4> cars will be very popular soon. Failure of the pump drive is not common on the BWE, what is common is a sludged up sump due to the stupid Audi oil chnage intervals.
  4. Re: Oil pressure warning light. Not sure what to do..
    Jul 2016
    uk
    Thanks for the reply. Have you quoted that from somewhere?
  5. Re: Oil pressure warning light. Not sure what to do..
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Baz1977 View Post
    I'm pretty sure Crasher just knows this stuff - he's an expert. Look up C&R Enterprises online and you'll see what I mean...
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
    1 1 0
  6. Re: Oil pressure warning light. Not sure what to do..
    1840 Post(s)
    No, it came out of my head.... including spelling change incorrectly.....
  1. Oil Pressure Warning Light
    By Seeds in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-12-2017, 02:08 PM
  2. Oil Pressure Warning Light - oh what fun
    By jimboozle in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-12-2014, 05:00 PM
  3. oil pressure warning light
    By jclayton76 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2009, 12:57 PM
  4. Please Help oil pressure warning light
    By david parker in forum Alhambra
    Last Post: 21-03-2009, 08:30 AM
  5. Oil Pressure warning light.
    By benGT in forum Golf MK4 - 1999 - 2004
    Last Post: 01-12-2008, 11:53 AM
