Thread: 2003 Allroad - Suspension sinking evenly at the front very slowly.
Results 1 to 8 of 8
  1. 2003 Allroad - Suspension sinking evenly at the front very slowly.
    Jan 2018
    London
    Hi All,
    I have a 2003 Allroad that has had all of the airbags replaced as they have failed. I now have an issue where the front will sink evenly, but very slowly. It takes about a week without it being moved to even notice.
    I'm fairly certain that both front airbags are Arnott, and the oldest is probably 4-5 years old. I dont think it would be the airbags, because it is sinking evenly and it takes a while to go down 2-3 inches. The reservoir seems to be holding pressure because as soon as I turn the ignition (without starting) it pops straight back up, without running the compressor.
    Has anyone else seen this? Could it be sensors? Does the pipework degrade? The garage said it was sinking too slowly to be able to diagnose it without having it for weeks.
    Any ideas appreciated.
    Doug.
  2. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Most leaks come from airbags, sometimes you can also find leaks from the air pressur hoses connectors (N17 ). 6 on the valves block, 1 on the compressor, On the front air spring 1 each, On rear air spring 3 each. Testing with soapy water can help you. About three years ago Arnott produced an improved model of air spring (first generation) with Continental air bags also with a lifetime warranty(.You can see the Continental logo on the air bag instead of the Arnott logo) Mounted on my AR been four years Without any problem.
    N-17 # 4B0616751
  3. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Soapy water spray over all air bellow connections and work back to reservoir etc. looking for air bubbles. Be patient, as a slow leaking connector can take a few seconds to show.
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    1840 Post(s)
    Arnot air bags are rubbish, the vintage you have suffer from bump stop failure which disintegrates and cuts into the airbag from the inside out. A leak in one will make both deflate.
  5. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    Jan 2018
    London
    Thanks all for the replies. I guess this is what you sign up for when you own an allroad. I still love it though!
    soapy water it is...
  6. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    1840 Post(s)
    AllRoad, AKA die Geldgrube......
  7. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    Jan 2018
    London
    And I've got the 2.7T just for good measure. Sucker for punishment.
  8. Re: 2003 Allroad - Suspension sinking evenly at the front very slowly.
    1840 Post(s)
    uuuuuurrrrrggggghhhh, EGT sensor failure, effin sketch if they gall their thread, downpipe off which means turbo off which means engine out, awful
  1. That Sinking Feeling - A6 Allroad air suspension problems
    By footfang in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-03-2018, 11:23 PM
  2. a6 allroad front suspension rattle
    By chris.d in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-02-2016, 06:23 PM
  3. allroad suspension high at front
    By herald in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-12-2010, 08:47 AM
  4. Allroad sinking suspension.
    By mplews67 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-06-2009, 10:16 PM
  5. Allroad Front Suspension Parts
    By stewartbuckland in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-01-2009, 08:04 PM
