Thread: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
Results 11 to 20 of 22
  1. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    Dec 2014
    Bedford
    42 Post(s)
    That's the igniter
  2. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    Dec 2014
    Bedford
    42 Post(s)
    If its not in the doors or b pillars. Then under rear seats/ c pillar area is all thats left.
  3. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    Dec 2014
    Bedford
    42 Post(s)
    Quote Originally Posted by FLAPPERJACK76 View Post
    Like here.
  4. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    6 Post(s)
    Its snowing here and im sick of the thing!
    Ill pull up the carpet and follow the wires that goes through the floor pan toward front of car this must lead to the sensor? I read mk 4 golf has sensor where the sill is nut couldnt feel it and will be easier with carpet up.
    Thanks for helping
    Sent from my SM-G935F using Tapatalk
    1 1 0
  5. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    6 Post(s)
    Quote Originally Posted by robert1z View Post
    Thanks for helping
    Hallelujah!
  6. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    6 Post(s)
    The sensor is in front of the seat toward the sill.
    I have cleaned up the connections and ran vag again but i am still getting short to ground?
    When i remove the plug i get open circuit error instead.
    Does this help narrow down the problem?
  7. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    #17
    Dec 2014
    Bedford
    42 Post(s)
    Well done finding it . Its tricky working on the airbag wiring. I would swap one side with the other and see . I would guess though usually a short to earth is majority of the time the component. Also ties into the water leak you had that has ruined it.
    1 1 0
  8. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    #18
    Dec 2014
    Bedford
    42 Post(s)
    Also if it were my motor , those rubber bungs in the floor i would pearce them with a pointy screwdriver. So if you ever have a leak internally the water gets out.
  9. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    #19
    6 Post(s)
    Yeah. Satisfaction of finding is something! Im trying to dry it out tonight and Ill swap the sensors round tomorrow. If not it must be a break in the wire between the seat and the crash sensor which is only a small section? I would not have to trace back to airbag unit in dash or anything - thats really tightly packed wiring! First things first i suppose I shall swap first.
  10. Re: Vw polo 1.4 tdi 9n Crash Sensor Side Airbag Driver Side location
    #20
    Dec 2014
    Bedford
    42 Post(s)
    Also another good idea worth mentioning. Always disconnect the earth on the battery when working on the airbag wiring. Always grab the door striker on the door b pillar before you touch the wiring. And put the ignition to the on position before connecting the battery earth. This way if you have fluffed something up and the worse should happen like the airbag goes off , it goes off while your under the bonnet and not in your face .
  1. 01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    By Adel75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2017, 05:47 PM
  2. Oh the Airbag Light... 01217 Side Airbag Igniter Driver Side (N199)
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-02-2015, 02:47 PM
  3. Replies: 8
    Last Post: 06-11-2014, 09:56 AM
  4. Please Help VW Polo 2008 side airbag fault crash sensor 6Q0909606K
    By Naj23 in forum Polo - Derby - Lupo - Fox
    Last Post: 20-07-2012, 11:16 AM
  5. Driver's Side Crash Sensor Position
    By EddieUK in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-04-2010, 11:11 PM
