Thread: fuel pressure?
  1. fuel pressure?
    Nov 2016
    ireland
    I have a audi b6 1.8t quattro 166hp model. Can anyone confirm the stock fuel pressure on the returnless fuel system, the only thing i could find says 3.5bar.
    Also if it is 3.5bar would this be enough for 850cc injectors? I'm trying for 500-600hp.
  2. Re: fuel pressure?
    1836 Post(s)
    I can’t check from here which you have but it will be 3 or 4 Bar and 3 Bar if my memory is correct. The system can run 4 Bar easily but if you have a 3 Bar regulator the ECU would have to be recalibrated to make use of a 4 Bar regulator or the feeling correction map will just see it as over fuelling and correct for it within seconds. The best method is to fit an adjustable regulator with a gauge and a piggy back ECU system to make fuelling corcetins and lie to the factory ECU about what is going on.
  3. Re: fuel pressure?
    scotland
    39 Post(s)
    The b6 1.8 t has the return less fuel system, the pressure regulator is in the fuel filter.
  1. Limp mode, low fuel pressure, air in fuel lines
    By Mowbz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-03-2017, 06:24 PM
  2. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  3. S4 - Fuel Pressure
    By mgouldstone in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2008, 10:55 AM
  4. Fuel pressure
    By Niklock in forum Audi A3 - Archive Topics
    Last Post: 13-06-2008, 11:39 PM
  5. Low Fuel Pressure??
    By dallas in forum Archive posts
    Last Post: 02-07-2007, 11:15 PM
