Thread: Hard starting and power loss!
  1. Hard starting and power loss!
    Dec 2017
    Cornwall uk
    Hi all, I've got an 1.9 tdi that's experiencing difficulties starting, got to turn the engine over 4-5 times before it will actually run. When it finally starts there's a small power loss up until you hit 2000 rpm then it suddenly takes of as if nothing is wrong 🤔 And occasionally when I dip the clutch, say at a junction the engine will completely die!! But will start up ok again! Could it possibly be a fuel pump issue?
  2. Re: Hard starting and power loss!
    Jan 2009
    Birmingham
    35 Post(s)
    Do a scan on it first then go from there
  3. Re: Hard starting and power loss!
    Dec 2017
    Cornwall uk
    All the computer is saying is engine mount which isn't causing this issue. I've changed the fuel filter at a chance that it was blocked, although it's not due a service just yet, but no luck there. I'm at a complete loss because if it was a pump I would think it would show a fault code for it and I don't want to go buying one anyway because if it's not that then it's a lot of money spent for nothing! Any suggestions on what to try next?
  4. Re: Hard starting and power loss!
    Jan 2009
    Birmingham
    35 Post(s)
    check your egr valve and anti shudder valve are not gunked up
  5. Re: Hard starting and power loss!
    Dec 2017
    Cornwall uk
    The egr valve is deleted and has been for many years now so that's not the issue. Where abouts is the anti shudder valve located? And is it easy to take off? It's something I've never done before
  6. Re: Hard starting and power loss!
    Jan 2017
    Ilkeston, UK
    The anti shudder valve is part of the EGR valve so its you've removed the EGR it isn't there anymore.
  7. Re: Hard starting and power loss!
    chester
    17 Post(s)
    Remove the feed to the fuel filter,put it in a jar and see if fuel will pump on key on engine off.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  1. Question Sharan 2005 TDI loss of power and hard to start when warm starting
    By macka001 in forum Touran - Sharan - Caravelle
    Last Post: 16-06-2015, 08:23 AM
  2. Power loss & hard brake pedal
    By magebora in forum Bora - 1998 - 2005
    Last Post: 28-09-2011, 01:18 PM
  3. Hard brake pedal & power loss
    By bigmikeyoyo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-03-2011, 01:50 AM
  4. Question Brake pedal hard and loss of engine power
    By warriorsage in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-03-2011, 11:09 PM
  5. Few issues... Power loss, strange wiper problem, hard to start!
    By Kris214 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2008, 09:56 PM
