Thread: U041600 fault code 64 plate Polo
Results 1 to 10 of 11
  1. U041600 fault code 64 plate Polo
    Jan 2018
    Peterborough
    Good evening,
    Had my 64 plate Polo checked by a mechanic friend today following the engine warning light coming on and staying on a steady amber. He was stumped by the fault code that came up. It clears and remains off the 1st time you start the engine but returns the 2nd time.
    Code is U041600 - Invalid data received from vehicle dynamics control module.
    The Polo is a 1 litre petrol. Fault appears to have no effect on the car starting or running.
    Any help on what it means, what's causing it and possible solutions?
    Apologies if there's any other threads for this. I did use the search thing on the forum but couldn't find anything.
  2. Re: U041600 fault code 64 plate Polo
    20 Post(s)
    487 Post(s)
    It needs a proper code read using VAG specific equipment, what was he using, Autel?
  3. Re: U041600 fault code 64 plate Polo
    Jan 2018
    Peterborough
    I am unsure of his equipment but does that mean you think that code has come up and isn't clear because he hasn't used a VW scanner? Need to go to a dealer/VW specialist?
  4. Re: U041600 fault code 64 plate Polo
    20 Post(s)
    487 Post(s)
    The code is not of a format I recognise, I am used to VAG specific codes or at least P codes.
  5. Re: U041600 fault code 64 plate Polo
    Apr 2018
    Did you find out what was wrong with your car? The exact thing is happening to my Girlfriend's car. The dealership wants 60 just to plug it into their computer. Thanks
  6. Re: U041600 fault code 64 plate Polo
    20 Post(s)
    487 Post(s)
    Quote Originally Posted by Simon Murray View Post
    How do you know it is "The exact thing" if it has not been code read?
  7. Re: U041600 fault code 64 plate Polo
    Apr 2018
    My mechanic friend plugged his diagnostic to the car.
    The error comes and goes so not sure whether it's a loose fuse or relay. Simply guessing.
  8. Re: U041600 fault code 64 plate Polo
    20 Post(s)
    487 Post(s)
    If it is that same code I have not seen it and the format is one I don’t recognise so like the other chap I can only suggest a proper VAG compliant code read.
  9. Re: U041600 fault code 64 plate Polo
    Apr 2018
    No worries. Like I said, the error comes and goes so it seems like something not connected properly. Thanks anyway.
  10. Re: U041600 fault code 64 plate Polo
    20 Post(s)
    487 Post(s)
    If it generates an error it will be held in the memory so if you get a proper VAG compliant global scan done it should be very helpful. Try a local VAG independent specilsist, where are you?
  1. Question Polo 9N Fault Code 17961
    By bartleaj in forum Polo - Derby - Lupo - Fox
    Last Post: 22-04-2013, 08:46 AM
  2. Vw golf plus 05 plate . fault code
    By elliebumpkins in forum Golf Plus
    Last Post: 13-12-2011, 11:32 AM
  3. Please Help Polo Fault code p0172
    By martin77 in forum Polo - Derby - Lupo - Fox
    Last Post: 15-07-2011, 11:13 AM
  4. Fault Code Meaning's for A4 02 plate
    By Mr Sewell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-01-2010, 03:11 PM
  5. Please Help 55 plate Polo 1.2 ABS fault
    By jmbpolo55 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-09-2008, 06:07 PM
