Thread: Park Assist Error after Can Gateway upgrade from Version 1KO 907 530K
Results 1 to 1 of 1
  1. Park Assist Error after Can Gateway upgrade from Version 1KO 907 530K
    Jan 2018
    Wolverhampton UK
    Hi Everyone
    Having just joined the forum, I am hoping some nice person will be able to assist with an upgrade just completed from 1KO 907 530K to 1KO 907 530L - installed on our VW Touran 2.0 DI Sport 2007 due to parasitic drain on battery, after retrofitting RNS 510 version C with 5238 Software
    I finished installing the Can Bus Gateway half an hour ago, having printed each screen to be able to programme the replacement gateway with VCDS 17.1.3, after a drive round to clear Wheel Sensor, I have an error code, for what I believe to be PARK ASSIST (76)
    The error is as follows:
    1KO 919 283 A
    05 Einparkhilfe 0101
    Fault
    01299 Diagnostic Interface for Data Bus (J533)
    005 No or Incorrect Setting/Adaptation
    Park Assist (76) is ticked as per the print screens, no other faults/errors are showing
    There is one other thing, I have lost all streets in Navigation since the upgrade, presume I will have to reinstall to correct this - IF anyone knows better than me, then I will bow to your knowledge.
    Thank You in advance for any help you can afford.
    Gizmo WV
  1. Park Assist and Side Assist coding.
    By sany98 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-05-2015, 02:42 PM
  2. Park Assist - Anyone got it?
    By nheather in forum Golf MK6 - 2009 - 2013
    Last Post: 14-08-2011, 02:30 PM
  3. Attention VW PDC Park Assist
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2011, 04:49 PM
  4. £80 Park Assist
    By Berisford in forum Golf MK6 - 2009 - 2013
    Last Post: 04-07-2010, 02:09 PM
  5. Park Assist cannot park !!
    By dotaz in forum Golf MK6 - 2009 - 2013
    Last Post: 09-06-2010, 10:33 AM
