Thread: A6 Vibration problem
  1. A6 Vibration problem
    Aug 2016
    leicester
    I have just bought a 2003 a6 b5 avant and it has a bad vibration problem, I have owned lots of Audis over the years and never come across a problem like this one, it seems that the gearing is to high for the car, as if I'm driving in to high a gear, but that's not the problem, you can hear and feel the vibration in the car and it seems to get better as the car warms up, but that maybe just me thinking that, I have ruled out flywheel and clutch imbalance as its recently had a new clutch and flywheel, sometimes i can hear a click when pulling away, i thinking maybe engine, gearbox or subframe mounts maybe causing this, any suggestion please as this is driving me nuts, by the way its fine on the motorway and its just passed its mot.
  2. Re: A6 Vibration problem
    Jan 2009
    Nuneaton England
    Hi think you need to get the car up in the air and have a good look round it.
    What engine is it, what gearbox (auto manual)
    Sound like you may have a failed engine of gearbox mount or the exhaust is solid on the body
  3. Re: A6 Vibration problem
    Dec 2007
    8 Post(s)
    If the clutch change was very recent,you could check security of drive shaft bolts and flanges.
    The vibration may be from a drive shaft or inner cv joint.
  4. Re: A6 Vibration problem
    Aug 2016
    leicester
    Itís a 5 speed manual, awx 1.9 Diesel engine
  1. Solved Audi a4 avant vibration problem.
    By Pgammy1 in forum Chat - Anything with wheels
    Last Post: 29-11-2017, 01:44 PM
  2. problem with vibration when braking
    By noogman in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-01-2016, 12:26 PM
  3. Problem with brake vibration...
    By RobBentley in forum Passat - Archive Topics
    Last Post: 03-02-2008, 01:28 AM
  4. Vibration problem
    By clocksprings in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-02-2008, 10:31 PM
  5. A4 vibration problem
    By ian5509 in forum Audi A4 - Archive Topics
    Last Post: 21-04-2007, 12:41 PM
