Thread: Early 2009 Scirroco VCDS help
  1. Early 2009 Scirroco VCDS help
    Nov 2014
    Oxford
    Morning I have tried to get a retrofitted cruise control on an early 2009 Scirroco, with no luck! The part number of the cc unit is
    1ko 054 690a
    Firstly I can only use the basic coding 07 as for some reason the Coding II is greyed out! Have done the engine 01 coding and activated the bit for cruise control installed. Have done the steering wheel 16 and changed the coding for digit 5 to number 3 as described. All coding accepted but still no luck with getting it to work.
    Also I noticed there were 2 modules listed in the steering wheel section? is it possible I have coded the wrong one?/ Should I try to select the second module and code it as well??
  2. Re: Early 2009 Scirroco VCDS help
    Nov 2014
    Oxford
    Never mind it works, the car just doesn't have the display option lol........
  1. Replies: 4
    Last Post: 18-09-2016, 07:14 PM
  2. Replies: 3
    Last Post: 06-09-2014, 09:42 AM
  3. 2009 A6 2.0 tdi s line (170) VCDS options
    By nigedvd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-05-2012, 09:41 AM
  4. 2009-2010 CC VCDS autoscan anyone?
    By akipal in forum Passat CC
    Last Post: 27-10-2011, 09:11 PM
  5. Scirroco Cold Starting Issues.
    By BlazeMaguire in forum Scirocco - Corrado
    Last Post: 31-03-2008, 04:20 PM
