Thread: Airbag Light On - Causes
  1. Airbag Light On - Causes
    Nov 2017
    Newmilns
    Hi
    Recently had to investigate heater motor issue which involved removal of glove box etc, after re-assembly I now have a airbag light on on main display ( Passenger airbag appears to be activated- the disable switch for passenger bag is in the glove box and is set to enable and passenger bag disable light is off).
    I have an OBD wifi adpater/Torque Lite phone App - no ECU fault codes reported .
    Would starting car when glove box out ( passenger airbag de-activated) cause some weird ECU condition which might explain the fault light ?
    Any merit in disconnecting battery to get ECU to go through a clean power up ?
  2. Re: Airbag Light On - Causes
    Jul 2010
    Bradford, West Yorkshire
    If you turned the ignition on with the passenger airbag switch disconnected it would have stored a fault code. You will need a scanner to clear the code.
  1. Airbag light on.....airbag sensor location G180?
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-12-2016, 04:56 PM
  2. Disconnected passenger airbag key switch, now airbag light is on
    By garmcqui in forum Golf MK7 - 2013 - 2019
    Last Post: 13-03-2016, 06:38 PM
  3. Oh the Airbag Light... 01217 Side Airbag Igniter Driver Side (N199)
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-02-2015, 02:47 PM
  4. golf mk4 tdi airbag light and abs light
    By swally34 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-06-2013, 09:12 PM
  5. Please Help Engine Light & Airbag Light stay on
    By sobberz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-06-2010, 07:27 AM
