Thread: Fuse 4 blowing
  1. Fuse 4 blowing
    Oct 2017
    Bournemouth
    Hi....My low level oil light came on yesterday even though the level was fine. After some research I found it it was actually down to a blown fuse, in my case its Fuse 4 which is labelled as heater/ air condenser. I'm trying to find out firstly If anyone knows what is causing it to blow and secondly if someone can point me in the right direction for some wiring diagrams.
    Thanks in advance
    Jay
  2. Re: Fuse 4 blowing
    Jul 2010
    Bradford, West Yorkshire
    Fuse 4 actually powers quite a few different circuits
    You will need to establish which circuit is causing it
    Out of the list of possibles the likely culprits are as follows:
    Reverse lights
    Heated seats
    Heater system
    Engine oil sensor
  3. Re: Fuse 4 blowing
    Oct 2017
    Bournemouth
    Hi thanks for the reply zu11y.
    The fuse appears to blow when you turn the heater up so I removed the glove box and unplugged the blower but it still happened when I used the + button to increase the what would of turned the heating up. I then noticed that the reverse light didn't work I so removed the rear light to check the bulb which was ok, I even unplugged the light but the fuse still blew....I've also unplugged the air con unit and the high pressure switch and it still blew...
    Maybe the issue does lie with the reversing lights, I'll unplug the switch tomorrow and see what happens..
    I'll report back if I suss it, in the meantime...If anyone else has any info to share it would be greatly appreciated..
  4. Re: Fuse 4 blowing
    Jul 2010
    Did you unplug the heater resistor?
  5. Re: Fuse 4 blowing
    Oct 2017
    Bournemouth
    No I didn't zu11y, where is it?
  6. Re: Fuse 4 blowing
    Oct 2017
    Bournemouth
    No worries, I'v just googled it.....I'll try unplugging that tomorrow morning.
  7. Re: Fuse 4 blowing
    Oct 2017
    Bournemouth
    Ok I got it sorted, it was actually the air con high pressure switch...All happy now..
  1. Fuse 24 keeps blowing
    By TimmyChap in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-08-2016, 08:03 PM
  2. 170 TDI - Fuse F23 keeps blowing
    By kaycee944 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2012, 10:05 PM
  3. blowing fuse
    By chris356 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2010, 11:24 PM
  4. Question Fuse Blowing
    By moaning in forum 80 - 90
    Last Post: 03-08-2010, 11:40 PM
  5. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
