Thread: Rear washer corrugated hose snapped
  1. Rear washer corrugated hose snapped
    Jan 2018
    Bucks
    A couple of weeks back, the pressure of the rear washer dropped dramatically. On opening the boot, I could see water dripping down the seal of the boot and boot lid. I found that the corrugated hose had snapped. The point of failure was inside the rubber hosing next to the right hinge of the boot lid. Does anyone have any recommendations on how best to repair the snapped corrugated hose. I was thinking about a male-to-male hose connector, any other ideas?
  2. Re: Rear washer corrugated hose snapped
    Aug 2008
    Wigan
    9 Post(s)
    Sounds ok but I would look for what caused the break, chafing, flexing or something else. You may be better using two connectors and a tougher piece of hose at the point of wear, assuming you have enough access to cut the original hose for a reasonable length away from from the break.
  3. Re: Rear washer corrugated hose snapped
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by TonySV View Post
    I just used some standard washer hose. Cutting out the bad section and using T pieces to rejoin. Its very common.
    Ian
    A4 B6 Avant Nogaro Blue
  1. Rear Washer Hose Repair
    By johnsimcox in forum Polo - Derby - Lupo - Fox
    Last Post: 12-12-2016, 06:34 PM
  2. Question MK5 Golf Snapped Hose
    By MK5Kings in forum Golf MK5 - 2004 - 2009
    Last Post: 10-11-2016, 12:27 AM
  3. Rear washer hose leaking
    By dilly2008 in forum Chat - Anything with wheels
    Last Post: 06-06-2012, 10:52 AM
  4. Avant Rear washer hose route?
    By stickleback in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2011, 07:55 PM
  5. A6 Avant rear washer hose
    By kerrywalpole in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-04-2011, 04:02 PM
