Thread: Heater Motor Versions
  1. Heater Motor Versions
    Nov 2017
    Newmilns
    Hi looking for some help - my heater motor fan stopped working on my 2010 1.6TDI A3 (SB59UCL) - Auto climate Control version - stripped the parcel shelf out to access the blower and looks like all the right voltages getting to the motor - so motor needs replaced - motor PN listed as a 2820015G on the label - went onto ebay and purchased a replacement which appeared to be compatible , however when it arrived - when aligning the socket of new to old - noted that the outline was different and looked like it was not going to be a simple replacement - checking further saw that the PN listed on new one was 2820015A - question is does anyone know if this Rev A vs G is significant enough to explain the mismatch - in process of returning ebay purchase.
  2. Re: Heater Motor Versions
    Nov 2017
    Newmilns
    My inexperience showing here - after looking at the original motor again - I came to the conclusion that no difference between A & G,however after taking original motor out - noted that the fan was not rotating freely - after a few turns - original motor now working for the moment at least. If it goes again then at least I know that either an A or G version will fit the car :}
  3. Re: Heater Motor Versions
    Jul 2009
    uk
    I can only suggest you go to eurocarparts and type in your car reg. and search through to the heater motors and compare which is yours. I made a mistake like you.
    Mine had a electronic module fitted on the motor assembly where the standard has nothing if for a normal heating system.
    2008 A3 Quattro 2.0 TDi 170 bhp
    2009 A6 c6 Avant 2.7tdi LeMans
  1. Heater motor
    By taxi3528 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-05-2017, 09:10 PM
  2. Question Radiator Fan Motor Versions
    By MrC99 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-10-2010, 10:39 AM
  3. Question Heater Motor HELP!
    By waynex1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-07-2008, 06:21 PM
  4. New Heater Motor, But Still Not Right
    By Coupe16v in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 09-08-2007, 05:26 PM
  5. Heater motor A4
    By kered389 in forum Archive posts
    Last Post: 08-01-2007, 09:18 PM
