Thread: Torson Diff or Crown? Also huge Shuddering
  1. Torson Diff or Crown? Also huge Shuddering
    Apr 2009
    Hi, picked up a 2014 Q5 V6 3.0 Quattro S-Line plus Tiptronic from a dealership at the weekend. (49k miles.) Test drive was excellent, however when i got it home and making a three point turn, the wheels (Feels like Rear wheel) makes the car shudder as if its juddering against a high kerb and as if the wheels are about to fall off. It does it on both right & left turns. As its the weekend, im trying to get some info prior to returning to the garage on Monday morning to what it may be.
    Second question, which i dont know how relevant. A Torson Diff or Crown, i assume do the same things although i suspect i have a crown on this model, however, both i suspect would create a similar problem which im experiencing if either is faulty? Other forum users have spoken about the C.V.Joint as well. Without getting too bogged down with tech, would a Haldex maybe create this problem too? I hear if its not been serviced with an oil top up, its maybe dried out and creates juddering while slow cornering.
    Any advice would be appreciated.
    Thank you
  2. Re: Torson Diff or Crown? Also huge Shuddering
    Apr 2009
    I heard from garage today about the shuddering. Apparently when they removed the wheels to refurbish them, they never went back on the same order they came off. This, (According to Audi's report) is a common problem with the Quattro system.
    They have agreed to put a new set of rubber on the front axle which they say should sort it once and for all.
    Anyone else had the same?
  3. Re: Torson Diff or Crown? Also huge Shuddering
    Apr 2009
    Quote Originally Posted by r2sma View Post
    Had two new tyres fitted. The juddering has completely disappeared. The two tyres which were replaced were both Michelins with 3.0mm tread exactly on each. Therefore, does that mean whenever i get down to 3.0mm, im going to get the same problem?
  4. Re: Torson Diff or Crown? Also huge Shuddering
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Its usually more to do with un-equal tread depths on same, and or, front and rear axles. If your car now has similar tread depths they should be fine. May need swapping front to rear as they wear.
    Alan.
    VW T6 150 DSG Camper £££
  1. Huge Vibrations Please HELP !!!!!
    By gazcos in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-02-2017, 03:10 PM
  2. Huge thanks to BagpipingAndy & Gup
    By JimC64 in forum Chat - Completely Off Topic
    Last Post: 09-05-2015, 12:40 AM
  3. omg huge problem
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2011, 04:38 PM
  4. The Mk6 is Huge
    By moe360 in forum Golf MK6 - 2009 - 2013
    Last Post: 30-03-2010, 04:47 PM
  5. Huge TT Fan
    By Hefty in forum New Member Introductions
    Last Post: 14-08-2008, 08:19 PM
