Thread: 2006 1.9tdi Caddy - Fans Run with Ignition On
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: 2006 1.9tdi Caddy - Fans Run with Ignition On
    Jan 2018
    Midlands
    Engine light now on, which may be something unrelated, but it begs the question; is there two way communication between the ECU and fan conctroller?
  2. Re: 2006 1.9tdi Caddy - Fans Run with Ignition On
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I used to have a 1.9 pd tdi touran which had the intake flap (V157 ) fail, when it failed the fan stayed on continuously. I also had to change the intake flap on a relatives 1.9 fabia whose symptoms were the EML light coming on. I don't see anywhere in your posts that you've run a scan for codes but I suspect you will see a V157 related code for the EML being on, which might also tie in with your fans being on all the time. These throttle flaps / anti shudder flaps seem to fail pretty regular on older higher mileage cars, the ones I had to change had done around 100k and 70 odd k miles.
  3. Re: 2006 1.9tdi Caddy - Fans Run with Ignition On
    Jan 2018
    Midlands
    Thanks for that advice!
    No, I haven't done a scan; I usually get a friend to do it, but he is not around this weekend.
    I have ordered a reader. It was something I was getting around to, but as this is the first 'real' fault in two years owning the van, it just hasn't been a priority...
    Will post up some more details, later in the week, once I have checked the dtcs and done a component check on the coolant and aircon sensors; see if anything is out of place.
    I will read up on those flaps, too!
    Thanks again!
  4. Re: 2006 1.9tdi Caddy - Fans Run with Ignition On
    Jan 2018
    Midlands
    Code scanner came today
    So, I have no dtcs stored, since the aircon guy cleared them on Friday...
    Only one dtc pending: P0401 - Low EGR Flow
  1. Caddy ignition lock
    By andrewswe in forum Golf MK5 - 2004 - 2009
    Last Post: 16-08-2010, 07:31 PM
  2. 2006 caddy tdi
    By mickymac77 in forum The Commercial Range
    Last Post: 01-02-2010, 11:28 PM
  3. Alloys For a Caddy SDI 2006
    By PopeOfChiliTown in forum Wheels and Tyres
    Last Post: 30-12-2009, 11:40 PM
  4. Ignition Feed Caddy Van
    By Dairyman in forum The Commercial Range
    Last Post: 10-04-2008, 08:29 PM
  5. Caddy Ignition
    By bruwalsh in forum The Commercial Range
    Last Post: 14-09-2007, 09:08 PM
