Thread: High Bean Assist sensitivity
  1. High Bean Assist sensitivity
    Aug 2007
    Hook Hampshire
    21 Post(s)
    The sensitivity of the HBA is not as sensitive as it used to be and drivers are sometimes flashing me. Does anyone know what can be done or if there is an adjustment via VCDS.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: High Bean Assist sensitivity
    Feb 2013
    Gloucester
    57 Post(s)
    A really obvious one but have you cleaned the camera on the windscreen? If not the years of dust etc could be affecting it?
    Sent from my iPhone using Tapatalk Pro
  3. Re: High Bean Assist sensitivity
    Mar 2008
    11 Post(s)
    I wonder if it's just more obvious at the moment as it's dark + weather is rubbish.
    I too have noticed a few people flashing however visually, I think it's quick enough to close up the lights so to speak and at the right time. Only time it's probably not done the trick is on a dual carriageway bend and the opposite side has flashed.
    Then again I've had people flash even without HBA on - I think the LED lights are generally just a lot brighter and for the lower oncoming cars, maybe in their way.
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  4. Re: High Bean Assist sensitivity
    Mar 2008
    11 Post(s)
    I got another flash last night on Surrey's dark roads. I saw the right side dim down as the oncoming car approached however when I do get flashed, it's usually around this area where I'm at an incline slightly and the oncoming is on decline. I guess either the left side is still too bright or it's not dimming quick enough - the latter I'm not sure as I'm pretty certain i saw it dim prior to the lights being on the oncoming car.
  1. Question High-beam assist
    By jake25 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-03-2020, 04:00 PM
  2. How to use high beam assist?
    By Rauf786 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-10-2016, 01:38 PM
  3. High beam assist
    By Ivor Bigun in forum VCDS - General Questions
    Last Post: 22-06-2011, 12:15 PM
  4. High Beam assist
    By sabingli in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-06-2011, 05:49 PM
  5. high-beam assist
    By tlionhart in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-04-2009, 07:25 PM
