Thread: New member '08 A4 Avant 2.0tdi 170 problems already!!
  1. New member '08 A4 Avant 2.0tdi 170 problems already!!
    Jan 2018
    Cumbria
    Hi all, just before Christmas I bought myself the above car and all was going well. However now I have an engine management light on and flashing glow plug light...after speaking to someone and showing them the registered codes they suggested it was an injector loom fault...replaced this at a cost of over £120 and still the faults are there.
    Does anyone else have any suggestions thanks
    04710 PD Unit Injector: Cylinder 3 (N242): Implausible Signal
    04704 PD Unit Injector: Cylinder 1 (N240): Implausible Signal
    04720 PD Unit Injector: Cylinder 4 (N243): Regulation Range Exceeded
    04711 PD Unit Injector: Cylinder 3 (N242): Regulation Range Exceeded
    04705 PD Unit Injector: Cylinder 1 (N240): Regulation Range Exceeded
    04713 PD Unit Injector: Cylinder 4 (N243): Implausible Signal
    01651 Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
    01652 Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
    12546 Motor for Intake Manifold Flap (V157): No Signal
    05214 *Mass Air Flow*during Regeneration too Low*
    13171 ????
  2. Re: New member '08 A4 Avant 2.0tdi 170 problems already!!
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I've had to replace a few of the intake manifold flaps ( V157) on 1.9 pd engines, that could be giving you the 12546 and 5214 codes. I'm presuming whoever replaced the loom cleared the original fault codes and they have all since come back?you need someone with vcds to see what the injectors are doing.
  1. New member looking for help 2010 Audi A6 3.0TDI Avant
    By stevejw1185 in forum New Member Introductions
    Last Post: 08-07-2017, 03:24 PM
  2. New Member Audi A8 D3 3.0tdi help!!!
    By msadiq in forum A8 - S8 - V8
    Last Post: 22-01-2017, 06:19 PM
  3. A8 4.0TDi ... new owner ... old member
    By Jabba in forum A8 - S8 - V8
    Last Post: 02-07-2014, 05:31 PM
  4. Please Help Audi a6 avant 2.0tdi 2007 - mmi problems
    By Ivan Audi Fan in forum In Car Entertainment
    Last Post: 12-01-2014, 05:29 PM
  5. New member looking for a 3.0tdi Le Mans.
    By Happybiker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-08-2013, 08:13 AM
