Thread: Set The Time On MMI
  1. Set The Time On MMI
    Dec 2017
    Swansea, Wales
    I've got a newbie question. I've had my nearly new A1 Sportback for a few days and still can't work out how to set the time - it's currently one hour fast. I've read the book and watched videos which say that you press the Time "button" in the top left corner of the MMI. However, mine seems to be permanently greyed out. I assume I'm missing some obvious step. Anyone?
  2. Re: Set The Time On MMI
    May 2013
    Dorset
    The clock is being set by GPS or Radio automatically. The one hour different will be because of daylight savings.
    Where are you? Some countries have odd DST Settings and in that case you just have to live with it, or get VCDS and disable the auto clock setting.
    Is there an independent option for DST on/off you can set?
    Audi S1, Vegas Yellow, Contrast Black Roof/Black Pack, and all the other options except the Pano Roof. 284bhp/445Nm with FSR Tuning Box and Pedal Box
    Skoda Octavia vRS TDI DSG Estate, Rallye Green, and all the other options except the Pano Roof
    Audi SQ5. Now Sold
  3. Re: Set The Time On MMI
    Dec 2017
    Swansea, Wales
    Quote Originally Posted by josedebardi View Post
    Really? I'm in the UK. I've seen (on YouTube) the screen where you can choose which time source you want to use, whether you want it to automatically adjust for DST, etc, but I can't get into that screen because my Time button is greyed out.
  4. Re: Set The Time On MMI
    May 2013
    Dorset
    Normally you can get into time but then the contents are greyed out.
    Have you tried it with engine running/ignition on/ignition off?
    I’m wondering if with the GPS antenna running or not it locks you out.
    Audi SQ5. Now Sold
  5. Re: Set The Time On MMI
    Dec 2017
    Swansea, Wales
    Pretty sure I've only tried with engine off, ignition off, so will have another go tomorrow. You mention GPS - I don't have the sat nav option so I guess the time isn't set by GPS. Would that be true?
  6. Re: Set The Time On MMI
    May 2013
    Dorset
    On newish models the antenna is still present. Or if not it takes it from the FM radio signal.
    Audi SQ5. Now Sold
  7. Re: Set The Time On MMI
    Dec 2017
    Swansea, Wales
    Sorted. The Time control button only works with the ignition on so I was able to go into the screen with all the time related settings and fix it. Thanks for your help.
  1. long time member - first time poster!
    By m33ufo in forum New Member Introductions
    Last Post: 29-06-2017, 04:39 PM
  2. Long time VW, first time Audi owner
    By NatHolloway in forum New Member Introductions
    Last Post: 30-12-2015, 10:14 AM
  3. 3rd brake light not working , no revs , engine mangement on from time to time
    By icemano3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-10-2013, 10:01 PM
  4. Long time lurker first time poster
    By m1ckl in forum New Member Introductions
    Last Post: 26-09-2009, 11:31 AM
  5. Question MK4 Golf - Complete lack of grip from time to time
    By nburgess in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 08:09 PM
